Broadband speed terrible
- Re: Broadband speed terrible
17-10-2014 3:02 PM
Hi
I'm still having problems with my broadband .
Its constantly drooping off and the speeds are 0.508mb
The internet was fine until BT speed 2 weeks cutting ivy off poles and digging around the wires.
I need this sorted out.
Regards
Chris
Regards
Chris
Message 1 of 4
(581 Views)
3 REPLIES 3
17-10-2014 3:13 PM
I assume that you have reported a fault - haven't they given a time for when it is expected to be fixed
Message 2 of 4
(361 Views)
17-10-2014 3:22 PM
Hi Oldjim
I was on last week about the problem I was experiencing but when checked from the plusnet side they said everything seemed OK.
MY ping is 1756 download speed is 0.508mb
I've rebooted the router and unplugged to give it a fresh start but still no good.
Regards
Chris
Regards
Chris
Message 3 of 4
(361 Views)
17-10-2014 3:37 PM
Can you post the information requested here and we should be able to advise http://community.plus.net/forum/index.php/topic,96155.0.html
Message 4 of 4
(361 Views)
