Broadband speed slower than expected
- Broadband speed slower than expected
16-02-2010 10:45 AM
I don't have Java applets so can't run the BT speedtest. No matter what other tester I run it's always about
2.7MB download speed, for example:
Hope there is sufficient info here:
Exchange EABCY
Phone exchange:
BILLERICAY
Estimated line speed:
5 - Checked on 2009-09-11 10:17:16
Current line speed:
3000
Peak usage: 4.06 GB 8am – Midnight
Off-peak usage: 169 MB Midnight – 8am
Total usage 4.23 GB
From my Voyager 240 Router:
Line mode G.dmt
Line state Show Time
Latency Type Interleave
Line Coding Trellis Off
Line Up Count 1
Statistics Downstream Upstream
Line Rate 3840 Kbps 448 Kbps
Noise Margin 8.6 dB 21.0 dB
Line Attenuation 30.5 dB 22.0 dB
Output Power 18.6 dBm 11.9 dBm
K 121 15
R 12 16
S 1 8
D 16 2
Super Frames 416973 416971
Super Frame Errors 14 0
RS Words 28354231 3544253
RS Correctable Errors 1487 7
RS Uncorrectable Errors 49 0
HEC Errors 11 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
Test the connection to your ADSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping: PASS
Test ATM OAM F5 end-to-end ping: PASS
Test ATM OAM F4 segment ping: FAIL
Test ATM OAM F4 end-to-end ping: FAIL
Test the connection to your Internet service provider
Test PPP server connection: PASS
Test authentication with ISP: PASS
Test the assigned IP address: PASS
Ping default gateway: PASS
Ping primary Domain Name Server: PASS
I have checked all my connections/filters
Could you please see if a speed increase is possible thanks.
Re: Broadband speed slower than expected
16-02-2010 10:54 AM
Can you plug the router into the test socket with nothing else connected and advise the noise margin, attenuation and speeds
16-02-2010 11:52 AM
is in the garage. Here are the results:
Connected to the test socket, nothing else connected:
Line Rate 5312 Kbps 448 Kbps
Noise Margin 11.0 dB 19.0 dB
Output Power 19.6 dBm 11.9 dBm
K 167 15
R 14 16
S 1 8
D 16 2
Super Frames 15878 15876
Super Frame Errors 1 0
RS Words 1079766 134946
RS Correctable Errors 49 0
RS Uncorrectable Errors 1 0
HEC Errors 1 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
I notice the downstream line rate has gone up but the connection speed is still about the same.
Thanks for your help.
16-02-2010 11:59 AM
The point is the downstream sync speed which has increased from 3840 @ 8.6dB to 5312 @11dB
This gives us two bits of useful information.
Your default noise margin as set by the exchange is probably 12dB (probably due to problems with your connection from the other socket) and much more important your internal wiring is badly affecting your sync speeds.
With a master socket in the garage you are very limited in what you can do.
Can you post a photo of the wires attached the removable faceplate of the master socket
16-02-2010 1:31 PM
The black wire is the main incoming wire. The other three wires go to sockets
inside the house. The phone below the socket is never connected.
16-02-2010 1:50 PM
Without wishing to be impolite - how competent would you feel in relation to modifying the phone wiring.
If you just want to take the first easy step you could try a BT Iplate which doesn't require any fiddling with the wiring as it just clips into your master socket between the removable faceplate and the socket
http://www.shop.bt.com/content/uni2/documentation/58lt/iplate_8pp_booklet_v2_iplate_instruction_book...
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=7256
If you want to take it further can you advise how many sockets you have in the house and how convenient/difficult would it be to run a new cable from the master socket to the router
A further question - are all three wires feeding sockets you use and are the two upper wires different (round instead of flat) to the third wire
16-02-2010 3:21 PM
stats:
Line Rate 4512 Kbps 448 Kbps
Noise Margin 8.3 dB 19.0 dB
Output Power 19.0 dBm 11.9 dBm
One of the upper white wires goes to a socket that we never use. The two upper
wires are indeed round, not flat like the one that comes out of the side (this is the one that
feeds the indoor socket that the router uses).
I'll get an I-plate as well.
Will the above improvement result in a faster broadband connection?
If you plug the router into the front of the main socket in the garage (not the test socket inside
which gives the best stats) you now get roughly the same readings (above) as using the
original indoor socket for the router.
16-02-2010 3:41 PM
With an attenuation of 30.5db, you should be able to get much higher than this.
Are all other sockets that are in use filtered?
16-02-2010 3:59 PM
16-02-2010 4:08 PM
Not sure how old the filters are nor what quality they are, but while the credit card is out get some (or one) of these http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=1652 Always come in handy as a spare.
Also, try unplugging all phones and thus just leaving the router attached. Then add one phone at a time just to see if there is any change.
17-02-2010 10:33 AM
Line Rate 5984 Kbps 448 Kbps
Noise Margin 8.6 dB 20.0 dB
Line Attenuation 31.0 dB 22.0 dB
Ran a speedtest and no change:
Tried disconnecting all phones at the sockets. All filters are good quality but changed them round
anyway. No improvement in connection speed.
Is there anything I or Plusnet can do now to speed up the connection or is it a local exchange issue?
17-02-2010 12:28 PM
17-02-2010 12:53 PM
continuously to have the ip profile updated?
Thanks everyone for your help
17-02-2010 12:59 PM
17-02-2010 1:28 PM
