Broadband speed not right yet
elkieluca
Hi when the engineer left two days ago he had fixed the outside wiring which had rotted and said now my speed should be at least 16 - 17 Mbps.  But it's stayed at 13 Mbps.  Could someone take a look at this for me please.
5 REPLIES 5
MatthewWheeler
Fixes: 479
Re: Broadband speed not right yet
I think he may have been referring to the actual sync speed rather then throughput speed.
Your profile on our and our suppliers systems is set at around 15mbps so you should be getting this.
 Matthew Wheeler
elkieluca
Thanks Matthew do you mean I should be getting 15 as it's still just making 13 Mbps.
Fixes: 160
Hi Mary,
Can you please post your router stats?
Were you DATA speed tests performed over a wireless or wired connection (PC to router)?
Kevin
elkieluca
My broadband speed has gradually risen to 16.14 Mbps since the engineer was here so it's all good now.
Chris
Legend
Fixes: 169
Excellent, that sounds a lot closer to where it should be.
