Broadband speed loss
choddychod
Download speedachieved during the test was - 1.54 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :2.46 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.75 Mbps
I noticed that my broadband speed had dropped a few days ago, I was synched at 2.5 and was getting 1.75 IP Profile.  I reset the router (left it off for 5 mins) and it resynched at 5.5 which is the usual speed.  The following day I checked the IP Profile and it was still 1.75 so I did another reset and it returned to 5.5 synch and 4.5 IP profile.
It did a couple of disconnects and dropped back down to what it is now.  A 5 min switch off no longer gets it to synch back to 5.5.
ADSL Link Downstream Upstream Link Rate 2464 Kbps 448 Kbps Line Attenuation 38.5 dB 24.0 dB Noise Margin 11.5 dB 21.0 dB
