Broadband speed just dropped?
jasonfreeman
My broadband speed is around 17mbps but suddenly tonight my speed has dropped to around 9mbps?
jasonfreeman
Re: Broadband speed just dropped?
For some reason my IP profile has dropped my broadband speed has dropped and I don't know why. These were the results of my BT diagnostics test:
Download speed achieved during the test was - 8.97 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.54 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 5
Are your speeds back to normal now?
Chris Pettitt
Cloud Environments Engineer
jasonfreeman
nope my speed has dropped even more, these are the BT diagnostics results i have just done:
Download speed achieved during the test was - 6.16 Mbps
IP Profile for your line is - 18.09 Mbps
Fixes: 55
Hi Jason,
I've updated the profile back to 18100kbps for you.
 Adam Walker
jasonfreeman
thank you adam and also my broadband just disconnected again just now and speeds are still slow
jasonfreeman
my speeds are still slow and it takes ages for the internet to even load
Fixes: 55
Sorry to hear that Jason, you might want to try again now in case that was a bit soon after the profile change.
What does a test at http://speedtest.btwholesale.com/ show you?
 Adam Walker
jasonfreeman
Much better, the results now show:
Download speed achieved during the test was - 17.3 Mbps
colly05
wow your lucky mine droped a while back and it took 2 days for plus just to reply to my ticket
thesawdust
Jason is on ADSL2+ you are on Fibre
PlusNET can reset lines remotely on ADSL2+ but can't on Fibre  Cheesy
