Broadband speed has reduced by 50%
- Broadband speed has reduced by 50%
25-08-2016 11:20 AM
Good Morning.
My broadband speed has dropped by 50% over the pass two days.
Below are my router stats.
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A/L
Upstream | Downstream | |
Current Rate (Kbps) | 712 | 2739 |
Max Rate (Kbps) | 944 | 2544 |
SNR Margin (dB) | 4.6 | 2.1 |
Line Attenuation (dB) | 31.2 | 50 |
Errors (Pkts) | 0 | 0 |
Has there been a profile change on my account? I have been achieving a constant 6Mb connection over the past 12 months.
Re: Broadband speed has reduced by 50%
25-08-2016 11:47 AM
Our tests are shown what's known as a 'High Resistance' fault.
Have you gone through all the steps here?
25-08-2016 3:35 PM
Hi Matthew
The modem is plugged into the master socket has been re-booted, the microfilter has been changed but I see no change in the connection speed. We have had no problems since we have been with Plusnet and have had quite a stable 5-6Mb connection speed for the past 36 months while we have been at the property.
Mark
25-08-2016 3:42 PM
In that case I'd recommend raising this at https://faults.plus.net
