Broadband speed half what it was and below minimum guarantee
gadg17
I'm currently getting only 35Mb over ethernet to a fast PC. Was previouisly getting well over 60Mb.
BT Wholesale Advanced Report:
Friday 23 September 2022 | 19:24:48
Ping 11 Ms
Download 35.42 Mbps
Upload 18.52 Mbps
Download speed achieved during the test was 35.42 Mbps
For your connection, the acceptable range of speeds is 25.86 - 36.95 Mbps
IP Profile for your line is 36.95 Mbps
Upload speed achieved during the test was 18.52 Mbps
IP Profile for your line is 20 Mbps
BT Broadband Availability Checker reports Downstream Line Rate 76.3 (high) and 55 (low)
I'm paying for Unlimited Fibre Extra and had these figures from Plusnet after installation last October:
Estimated peak time speeds: Download: 46 - 64Mb; Upload: 10 - 15Mb
Current line speed: 61.6Mb
Minimum Guaranteed Speed: 40.5Mb
Am I being capped mistakenly or has the IP profile changed so that I can no longer get what I'm paying for? I've been through the connection refresh procedure via text message - no change.
Thanks for any advice
12 REPLIES 12
Fixes: 345
Re: Broadband speed half what it was and below minimum guarantee
@gadg17 When did you notice this speed reduction? At first glance, I would say there is a problem somewhere in the network.
First thing to check is your phone line - dial 17070, select option 2. Once your phone number is confirmed, there should be NO noise on the line apart from the regular 'Quiet Line Test' announcement - if there is any noise report a phone fault via: https://www.plus.net/help/report-a-problem/phone/
If the phone test passes, report a broadband problem via:https://www.plus.net/help/report-a-problem/broadband/
Please report back, whatever the result.
gadg17
Thanks for the response. Noticed the problem today while looking into whether to renew the contract.
The quiet line test is fine. I tried the 'report a broadband problem' link but it doesn't seem to have any option other than the text message check, which I've already tried.
However I've logged a complaint ticket so we'll see what they eventually say. Will post any updates.
David
Fixes: 345
OK - I wonder  how long it has been like this? If you don't get a response to the 'bot' report by (say) midday tomorrow, post back and say so - there are other options. It may take awhile for your ticket to be picked up - the 'Team' are 'busy'.
gadg17
Thanks - I will indeed.
gadg17
They called this morning - they're sending an engineer a week on Monday, so it's not going to be a remote fix.
TheMightyAJ
Fixes: 126
Thank you for reaching out to us @gadg17. I'm very sorry to read about the issues you've been having with your speeds. I can see that you've spoken to our support team this morning regarding this fault and that an investigation into this matter has been raised. I'd like to personally oversee this and so I've taken ownership of the complaint case you'd raised previously. I've logged an update confirming this, which can be accessed here.
If you have any further queries or issues, please don't hesitate to log them here in your thread or (ideally) on the support ticket linked above Smiley
 Alex H
gadg17
@TheMightyAJ Thank you.
David
TheMightyAJ
Fixes: 126
No worries Smiley
 Alex H
Fixes: 345
Personally, as I initially replied, I would be interested in the resolution, and the steps taken to get there. 'Hiding' it in a ticket almost suggests there is something worth hiding?
TheMightyAJ
Fixes: 126
Not really, I just like to keep things between ourselves and the customer asking questions as much as possible. It makes it easier to keep the conversation flowing if it's somewhere we don't need to omit details for security and privacy purposes. For example, address details, or landline numbers, that sort of thing. Of course, if the OP wants to share info about the case, they're more than free to do so Smiley
 Alex H
Fixes: 345
I kind of get what you are saying, Alex, but unless there is more to this than a simple (or complex) network issue, then I don't see the point in hiding the details. If address/land line number details need to be shared - and they shouldn't be, you have them already - then a PM would suffice, surely.
TheMightyAJ
Fixes: 126
Hey @gadg17,
I hope you're doing well! I'm just checking back in with you today to ask how the connection's been since we last spoke? I've tested the line today and everything appears to be running fine on our end, with the speed currently syncing at 60Mbps down. Just let me know if you've run into any issues and I'll get back to you as soon as possible Smiley
 Alex H
