Broadband speed dropping
Lodge01
Hi, could someone please look into this for me?
Download speed has drastically dropped, & the connection is getting close to being unusable!
Thank you!
1. Best Effort Test:  -provides background information.
Download  Speed
0.88 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.88 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
IP Profile for your line is - 7.15 Mbps
10 REPLIES 10
adamwalker
Fixes: 221
Re: Broadband speed dropping
Hi @Lodge01
Tests aren't showing me any obvious problems so I'd advise heading to http://faults.plus.net if that's still an issue.
 Adam Walker
jelv
Fixes: 10
Does https://portal.plus.net/my.html?action=data_transfer_speed say your current line speed is 7.15Mb? If it does I suggest you try a single disconnect/connect via the router interface to see if that restores normal speeds.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Lodge01
Hi again, Thanks for replies!
Returned an extremely poor 0.14mbps speed test result today.
Estimated line speed:8Mb (Download speed could vary depending on line conditions.
Estimates are the maximum speeds that your phone line can support.
These speeds are dependent on the package you choose.)  - Checked on 2013-10-12 14:27:44
Current line speed:7.15 Mb
Have reset & interfaced with router, dis/reconnected service. Only just a mild improvement in speed.
Checking connectivity reveals frequent dropouts to gateway & DNS server 1 + 2.
Surprised to learn your not detecting this at your end!
Have checked all cables at my end, all is as it should be!
Will follow your fault link next.
Lodge01
Error
Sorry, An error occurred whilst processing your request.
The error has been recorded and our website team will investigate. Please try again later.
The above has twice been the end result of performing survey at http://faults.plus.net.
Please advise!
Lodge01
Can someone at Plusnet please help us fix this. Or at least offer some type of explanation.
We're unable to even use for leisure, in one family members case, complete very necessary work.
We're getting an Error message on the 'Faults link' previously posted.
adamwalker
Fixes: 221
Hi @Lodge01
A ticket has been raised to a "test errors" pool which means our faults team will be picking up what info we have so far and will be in touch ASAP with an update or if we need any other info from you.
 Adam Walker
Lodge01
O.k.
Thanks Adam!!!
Lodge01
Hi again, just letting you know I've had no contact from the PN team since Monday.
Here are our Router Stats:-
Uptime: 2 days, 2:08:46
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [MB/GB]: 206.10 / 1.42
Output Power (Up/Down) [dBm]: 12.0 / 19.8
Line Attenuation (Up/Down) [dB]: 15.5 / 28.5
SN Margin (Up/Down) [dB]: 22.0 / 13.3
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 8 / -
Loss of Signal (Local/Remote): 1 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 22 / -
FEC Errors (Up/Down): 11 / 3,898
CRC Errors (Up/Down): 7 / 18
HEC Errors (Up/Down): - / 18 / 67
And the current line speed:-
adamwalker
Fixes: 221
Glad to see you've had some replies to the ticket since you posted. It looks like we're just waiting for an issue preventing us from running a certain diagnostic test from being fixed, hoping to see that done today.
Adam
 Adam Walker
Lodge01
Good Morning,
Broadband appears to be back to around normal capacity this morning!
Your assistance in getting it sorted is very much appreciated!!
Cheer Adam. Cheers PlusNet!!
