Broadband speed drop off
FIXED- Subscribe to RSS Feed
- Re: Broadband speed drop off
22-09-2019 1:25 PM
Fixed! Go to the fix.
22-09-2019 3:35 PM
Hi @Brizzie,
Thanks for getting in touch.
I'm sorry that you've been experiencing a deterioration of the broadband speed and appreciate the frustration this is causing you. Please accept my apologies for this.
I could not see any attachments however these are not required as from the sound of it the issue is most likely caused by automatic system adjustments that come in place if there is noise on the line. I could see these adjustment levels were quite high to compensate for the noise, this would lead to a decline in the speed of the service as it is balance between the two.
I have set these adjustments to a lower level so you should see the speed improve over the next 24 hours, however if the issue persists please do come back to us.
Thanks - LF
22-09-2019 4:55 PM
Thank you so much for the swift reply. Look forward to an improvement in speed over the next few days,
22-09-2019 6:22 PM
Hi @Brizzie, thanks for getting back to me.
Not to worry, I hope that does resolve the issue however do let us know if you need any further assistance.
Thanks - Tahir
