Broadband speed checker
Fixes: 9
The following message has been on the Plusnet broadband speed checker for weeks,
Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
Seems to be giving me the results I would expect, I know it says, ' may display misleading results ' but is it fixed with this being an old message ?
Fixes: 21
Re: Broadband speed checker
Gave me expected results this morning. I understood from a post on here a while back that it gave misleading results when it was under heavy load - presumably that means the server can't cope  Roll eyes
Heloman
I've been checking it regularly over the last couple of weeks and it seems to be working just fine now. The results it gives match almost exactly what I get from other speedcheck sites.
I suspect this is because very few people use it now and so it doesn't get overloaded.
