Broadband speed below 38mbps
niallr
My intenet speed recently at any time of day is showing 25mbps (max). Previously this use to show close to the max of 38mbps. Any ideas?
Tags (1)
1 REPLY 1
Legend
Fixes: 233
Re: Broadband speed below 38mbps
@niallr You probably have a BT/OR network issue.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
