Broadband speed = 0.26 Mbps
AntoineUK
Hello,
My broadband speed is 0,26 Mbps ......
Here is the BT performance test result :
Here is the attenuation info from the router :
One month ago it was around 7 Mbps. I went on holidays and when I am back it's 0.26 Mbps.
I haven't changed anything and I am on the master socket.
I tried to take the BT test further but it asks to change the broadband username/password in the router settings and if I do, I will lose them.
So I have 2 questions :
1. Can you help me with the speed problem ?
2. Do you know where I can find my  broadband username/password so I can run the BT test further ?
Thank you
Antoine
8 REPLIES 8
SpendLessTime
Fixes: 86
Re: Broadband speed = 0.4 Mbps
Hi @AntoineUK
You may want to edit the post as it shows your Plusnet username in the router details page.
AntoineUK
Ok thank you, I edited my post.
Can anyone help me ?
Thank you
Antoine
aesmith
Fixes: 4
Looking at your first post your router's connecting at just over 9meg, which is fine, and the BT test shows an IP profile of 8.26meg which is also fine.   What's your Plusnet "Current Line Speed" as shown on this link? ... https://portal.plus.net/my.html?action=data_transfer_speed
Apart from that what about issues your end, if your testing over wireless have you tried Ethernet?
AntoineUK
Hi aesmith,
Ok I connected through Ethernet this morning and here are the results :
What do you mean by "your router's connecting at just over 9meg" ?
I am plugged right in the router, so I am pretty sure 0.2 Mbps 😕
--> Can anyone please help me ?
--> Also, can anyone tell me where to find the "broadband password" that is set by default in the router so that I can run the BT test further ?
Thank you
Antoinw
SpendLessTime
Fixes: 86
In the first post the data rate from your router details is shown as 1111/9360 which is measured in Kbps so your router is connected at
downstream   9.36Mbps
upstream       1.111Mbps
For the time being forget about running the BTW test that requires you to change the username/password in the router. (if you really want to run that test, BTW will tell you the BTW username and password on the next page when you click the continue button)
What is the Plusnet Line Speed as shown at https://portal.plus.net/my.html?action=data_transfer_speed
This Plusnet Line Speed is the fastest that your downstream line can run and should be set to just below the BTW IP Profile download speed. But sometimes it is set too low and can be corrected by Plusnet staff on the phone or Chat.
If this is the issue, once Plusnet and set it correctly and you have verified it, then you may need to disconnect  and reconnect to get that speed.
AntoineUK
Ok here is what I get when following the link you gave me.
I guess it means the speed is set to 8Mb but I still get 0.2 Mbps
Regarding the test for BT they do give me a username/password to use but I need the current password to be able to change it back once the test is finished (it is written in their own instructions).
Thank you very much for your help,
Antoine
SpendLessTime
Fixes: 86
The password for your router to connect to Plusnet is the same one as the password you used to connect to the Plusnet Portal to see the Plusnet Line Speed and the username is in format username@plusdsl.net were the username part is used to log onto the portal too.
So the portal speed is good so the fault is elsewhere.
Have you tried the Quiet Line test from the phone? Dial, preferable from a corded phone, 17070 and select option 2 for the quiet line test. Do you hear any noise?
If so, log a phone fault with your phone provider and don't mention the ADSL issue just the noise on the phone line. If you use Plusnet for the phone the fault finding is http://www.plus.net/help/phone/phone-line-troubleshooting/
If that is okay, from https://en.wikipedia.org/wiki/British_telephone_sockets what type of phone socket do you have?
The aim is to plug the router into the BT test socket, if you have one hidden in the phone socket, so that any internal cabling can be taken out of the question and to see if the line speed improves.
AntoineUK
Thank you for your message. In the meantiime I opened a ticket on the broadband troobleshooting website. They havent given any feeback but now I come back from a 2 hours walk outside and I find the broadband speed back to 7 Mbps ....
So I really have no idea what they did but it's all fixed now.
I hope it won't happen again, else I don't know what to do 😕
Anyway thanks a lot for your help
Antoine
