Broadband slower and slower
Darrenj
Anyone else getting really poor performance in the evening. Really slower aftet 5pm (not great before). Just tested and results of download .89mb upload .12mb and latency 405ms
Any ideas?
4 REPLIES 4
hexa
Re: Broadband slower and slower
yeah my speed is usually just over 1MBS right now it's down to a very noticable 400KBs... what is going on
Fixes: 1,600
Hi there @Darrenj and @hexa
Our tests aren't detecting any issues.
Are you testing using a wired or wireless connection?
Darrenj
Hi Gandalf. Im using a wireless connection however at the time, a wired connection gave no greater speed. The issue does seem to be fixed however I do get regular intermittent very slow period of between 1-2 hours, this occassion was the whole night however.
Fixes: 1,600
Thanks for the info
When you're getting slow speeds again, can you run a BT speedtest for me please at http://www.speedtest.btwholesale.com using a wired connection. Once you have the result, please complete the further diagnostics.
Cheers
