Broadband - slow speeds
coral54
We are having problems  due to low broadband speeds. We have turned the router on and off as suggested and done a speed test which shows both output and input are below 10.
I have sent a text message asking for help on two occasions now. ( last night and this morning) but have had no response.
I have taken screenshots of the speed tests, but who do I contact if 5hey are not responding?
4 REPLIES 4
Fixes: 334
Re: Broadband - slow speeds
@coral54 Welcome to the forums. Which service  and router do you have - I'm guessing FTTC, but we do need to know some basic details in order to advise.
coral54
Thanks John.
our Broadband is a  Fibre to cabinet connection and we have upgraded to the Plusnet Hub Two router.
I have just done another speed test and the download speed has improved to 17.68 Mbps and the Upload speed is 9.33 Mbps, which are well below what was promised.
Fixes: 334
Thanks, @coral54 for that info.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. - if it will run ,This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
SammyM
Fixes: 101
Hiya @coral54
I'm sorry you are experiencing an issue with your speed and for the hassle this is causing you.
Testing is not picking up a fault and it is showing the speed to the router as 40Mbps.
Could you give the steps @jab1 suggested and let us know the results.
 Sammy M - Sheffield Team
