Broadband slow and no dial tone
- Broadband slow and no dial tone
28-11-2010 10:57 AM
Have tested everything in the house and unplugged everything. Checked for damage on cable from pole to house and nothing looks bad. Apparently though its a fault in my house so I have to pay for the engineer... very annoyed but lets hope its not me and it is a BT fault....
that's all, just venting....
Re: Broadband slow and no dial tone
28-11-2010 11:01 AM
If there isn't a dial tone then it isn't a fault in your property.
Have you reported it as a phone fault to your telephone service provider which is what you should have done
28-11-2010 11:55 AM
28-11-2010 4:03 PM
Just to say it is indeed possible to have really bad broadband and no dial tone.
If one of the two wires coming into your property is broken - and it does indeed depend on which one it is - a situation arises where the broadband will still work albeit very badly - but you are unable to make/receive a voice phone call
Additionally the exchange dslam will have reduced the ADSL sync rate and IP setting very considerably.
As other have said you need to fix the voice fault first - then sort out the broadband speed.
You may find the SNR margin has been upped by the exchange due to the fault and will need to be reset by plunet/BT once the fault has been fixed and the line can be re-tested for its stability
It's all happened to me................
Most likely place for an external fault is inside the street box (assuming there is no obvious damaged like a branch through or rubbing against an overhead line)
28-11-2010 4:50 PM
On the broadband side it is syncing at 0.1mbps and my IP setting is something like 400k whereas its normally 6000k ish. It disconnects every few hours as well.
Thanks for the tips, I understand my speed will start to rise over the first 5 days once my line is more stable.
I think I will have to bite the bullet and get the engineer out, the wife isn't too happy with having no home phone to natter on!!!
28-11-2010 4:51 PM
28-11-2010 5:51 PM
28-11-2010 6:08 PM
28-11-2010 8:57 PM
Quote from: x47c
Me too, and it was a fault at the junction under the street.
02-12-2010 9:57 AM
However, my internet is still very slow. I can only assume this is due to the ADSL sync rate and IP setting etc being set low due to the bad connection. I am not sure if plusnet can force a quicker up in speed or if I have to wait for a few days for it to pick back up.
Thanks everyone for your advice! Its great to see such a heplful community!
02-12-2010 10:35 AM
02-12-2010 10:45 AM
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,544
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 21.5 / 39.0
SN Margin (Up/Down) [dB]: 22.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 118
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
BT Test results
Download speedachieved during the test was - 115 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :4544 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
02-12-2010 10:50 AM
If you have no dial tone then you should first troubleshoot your phone connection before thinking about your broadband, as any phone problem will invariably affect your broadband. Have a look here for how to tackle phone problems.
Jojo
02-12-2010 10:53 AM
My phone now has a dial tone from today and that problem is all fixed. The issue is now that I have a low IP profile (135k) due to the issues I had previously. I was just wondering if there was anything that could be done or do I just need to wait for it to increase on it on.
Danny
02-12-2010 11:03 AM
It looks like your target noise margin has been pushed up to 15. I think you have a strong case for asking for that to be reset.
