Broadband slow and cutting out
hocumgday
Hi can someone check my connection as i am getting intermittent connections and when i do have one it is painfully slow.
I have recently had an engineer out and it was fine for a while.
this seems to be a recurring problem as this will be the 5th time i have had to contact plusnet.
I have tested the line as per instructions and also listened for noise.
9 REPLIES 9
Anotherone
Champion
Fixes: 21
Re: Broadband slow and cutting out
Full xDSL stats would be helpful to enable any constructive comment. See sig for direct link to stats. Also your Current Line speed (Login required) - don't post your phone number.
MatthewWheeler
Fixes: 479
I can see you have a fault raised but we aren't seeing many drops from our end here.
Just to confirm do you connect over a wired or wireless connection?
 Matthew Wheeler
Anotherone
Champion
Fixes: 21
The other bit of info that would be handy hocumgday, is how long on this occasion have you been seeing the intermittent connections?
hocumgday
Quote from: Matthew
My connection is wireless...it seems to be the exchange throttling me everytime this happens.
its been going on for a few days now
hocumgday
Im getting speeds of 0.7mbs
MatthewWheeler
Fixes: 479
Is it possible for you to try a wired connection to see if thats any better?
 Matthew Wheeler
Fixes: 159
Where these three threads fully concluded?
http://community.plus.net/forum/index.php/topic,131494.msg1162891.html#msg1162891
http://community.plus.net/forum/index.php/topic,133029.msg1162590.html#msg1162590
http://community.plus.net/forum/index.php/topic,131494.msg1148449.html#msg1148449
hocumgday
Quote from: Matthew
I only use iPads and iPhone for connection and they can't be wired, I've been with you for 7 years so any chance of a free router maybe?
Would be nice ;0)
Fixes: 159
Why do you want a new router?  There has been no evidence offered to suggest the location of the issue, so a new router is not (at this stage) going to help anything.
I'll ask the question again - did you complete the actions on the three previous threads please?
Whilst there is a suspected problem to investigate, running speed DATA speeds tests is not overly helpful (especially over WiFi* to an iPad) - please gather the information asked for in the speed issues link below.  Please do a quiet line test - dial 17070 option 2 using a corded phone plugged into the master socket.
*The issues you are seeing could be solely down to WiFi channel conflict in your area.  Go to the help assistant (link below) and look up WiFi trouble shooting.
