Broadband setup
mattdanielc
Broadband setup
Hello
I have recently joined plusnet, and as such my order tracker currently gives this status:
The activation process normally takes between 7 and 10 days until your line is activated. Your activation date
An engineer will activate your broadband on:
31st Jan 2008 - After 12pm
Does this mean I should be at home on the 31st?  Or does it matter if I am at home or not?  I presume the hardware I ordered will arrive before then too?
Thanks, will appreciate any help...
Fixes: 162
Re: Broadband setup
You don't need to be at home for this, the work is performed at the exchange.
The router should be ordered and delivered ready for the activation date.
 Chris Parr
 Plusnet Staff
mattdanielc
Re: Broadband setup
Quote from: Chris
brilliant, cheers mate, really appreciate the quick response.
Fixes: 162
Re: Broadband setup
No problem, shout up if you have any questions.
 Chris Parr
 Plusnet Staff
jonathand
Re: Broadband setup
Quote from: mattdanielc
Hello
Thanks for flagging this up.
I'll get onto updating this text to ensure it doesn't cause anyone else confusion.
robertbeavan
Re: Broadband setup
have just signed up aswell and looking forward to getting broadband at last!
it appears I'll need some more microfilters (i think you ship two as standard), as I've got a couple of phones and Sky TV.
Can I buy extra ones direct from you...Huh
James
Re: Broadband setup
Hi Robert,
We don't actually sell any microfilters apart from the couple that come with our routers.  You can easily pick them up in various stores like PC World and so on.
They're pretty cheap.
Re: Broadband setup
I've got one microfilter at the socket (one output to the router, and the phone line to everything else, including the phone and three Sky boxes), and had no problems. (but everything comes from the one socket, and I don't have extension sockets all over the place, so its fairly easy)
robertbeavan
Re: Broadband setup
ok - thanks... i'll try and get set-up with what i'm sent for free... if i have any issues, i'll just order a couple of extra filters..  Smiley
mattdanielc
Re: Broadband setup
hi hulls
maybe I'm having a blonde moment... but how do you get the phone and three sky boxes into 1 output?Huh
Thanks!
Re: Broadband setup
Single socket - to filter
filter splits
BB to the router
phone line to a splitter
the splitter goes to the phone (and daisy chains the Sky boxes). Cheesy
