Broadband set up but wont connect
- Broadband set up but wont connect
19-08-2010 2:57 PM
First off thanks for finishing my broadband order in time. However i have a problem.
The lights on the router are all lit up but when i click on internet explorer i cannot get it to view the page. It just says page not available for everything.
Message 1 of 4
(791 Views)
3 REPLIES 3
Re: Broadband set up but wont connect
19-08-2010 2:58 PM
just checked local internet settings and it shows ipv6 as limited?
Message 2 of 4
(405 Views)
19-08-2010 3:17 PM
dont worry now. its my pc, for some reason my ipv6 settings already had ip address and dns settings in so i just readjusted so they detected new ones and bang im here on home broadband
thanks
thanks
Message 3 of 4
(405 Views)
19-08-2010 3:40 PM
Hi stefonwade,
Thanks and no problem re the order. Just let us know if you need any more help. The regulars on here are a good bunch and will help out where they can plus you'll see us from the support side of things dropping in from time to time to.
Adam.
Adam.
Message 4 of 4
(405 Views)
