Broadband service outage Dunstable 04.08.2022
Brn
Since the morning 04.08.2022 our broadband is down, which I need for work.
The Plusnet service status page shows no faults.
However the text service check returns a "fault in your area" reply.
Anyone else experiencing the same or has information about this?
6 REPLIES 6
Fixes: 306
Re: Broadband service outage Dunstable 04.08.2022
@Brn Put your phone number in here: https://status.zen.co.uk/broadband/ and see if you get any result. If you don't  - post back.
Brn
Hi, thanks.
Returns BT82358 and BT82346 faults.
Fixes: 306
OK, so there is a local network issue. The PN service status only shows major faults - i.e. ones which affect a whole town/city, or a large part of one.
Brn
How accurate are those estimates for fault fixing?
Fixes: 306
Pessimistic, in most cases, unless they find further issues.
Brn
It has been fixed. Thanks for the help
