Broadband problems past few days - disconnections, slow speed
- Broadband problems past few days - disconnections,...
05-04-2024 11:04 AM
Hello,
I'm having problems over the past few days with disconnections and slow speed with my ADSL broadband.
Nothing has changed this end physically. Sometimes the phone has crackling but sometimes not.
Is there anyone from plusnet that can check my line for me please?
Thanks.
Re: Broadband problems past few days - disconnections, slow speed
05-04-2024 11:07 AM
@Okay If you hear noise on the phone - report a phone fault via: https://www.plus.net/help/report-a-problem/
05-04-2024 11:35 AM
05-04-2024 11:46 AM
@Okay Which router are you using, please?
05-04-2024 11:46 AM
Thanks for checking the line. Crackling is generally not bad, just maybe a burst of it if you listen for a while. Earlier while the modem was doing one of it's reconnects, I picked up the phone to check and if was very noisy then went away.
This is the only checks I have done, wanted to see if there was a problem with the line or at plusnet first as that has always been the case in the past.
I will plug the modem/router in the main socket next which means using wi-fi as it's in a different room. I normally use ethernet cable only. Will see how it goes for the rest of the day.
Thanks.
05-04-2024 11:48 AM
Hello john, I'm using a tp-link VR600 V3 with latest firmware.
05-04-2024 12:04 PM
Does that give any useful statistics - I'm not familiar with it? Your DSL uptime and noise margins would be a start.
05-04-2024 12:31 PM
Does this help?
| SNR Margin (dB) | 9.1 | 6 |
| Line Attenuation (dB) | 22.9 | 42.3 |
I'm now plugged into the master socket but not behind the plate as I don't have the right cable for that, or I can't find one so far. My master socket has separate phone and DSL sockets so I don't have to use filters.
05-04-2024 12:38 PM
Your SNR figures look OK, so that's one query out of the way. Is it possible to post the whole of the page you extracted that from - obscuring any private data?
Yo don't have a rats-tail filter hiding away then?
05-04-2024 12:53 PM
Keeps disconnecting still by the way even though in main socket.
More router stats:
Line Status: Connected
DSL Up Time: 0 days 0 hours 2 minutes
DSL Modulation Type: ADSL_2plus
Annex Type: Annex auto
| Upstream | Downstream | |
| Current Rate (kbps) | 888 | 9593 |
| Max Rate (kbps) | 888 | 10976 |
| SNR Margin (dB) | 10.3 | 6.1 |
| Line Attenuation (dB) | 23 | 42.5 |
| Errors (pkts) | 0 | 2 |
If there's anything specific you want me to check I'll see if I can find it.
I don't have any filters after the main socket at all.
05-04-2024 12:56 PM
Thanks for that. Can you post the event log please - something is not right here.
05-04-2024 12:57 PM
Any crackling on the line will disrupt the DSL connection, unless there is an obvious high resistant connector on your line, testing won't find it.
The Master socket face plate can be a cause of noise if it's poorly seated.
05-04-2024 1:35 PM
I cleared the log and set it to debug mode and just left it for a while without using web browser or anything else.
I removed the local IP address:
2024-04-05 13:15:36 [5] Httpd: Clear log.
2024-04-05 13:21:21 [5] System: DSL Link Down
2024-04-05 13:21:23 [6] PPP: Terminating on signal 15
2024-04-05 13:21:23 [6] PPP: Connect time 37.8 minutes.
2024-04-05 13:21:23 [6] PPP: Sent 587490 bytes, received 2425350 bytes.
2024-04-05 13:21:26 [5] System: DSL Training
2024-04-05 13:21:27 [6] PPP: Terminating on signal 15
2024-04-05 13:21:30 [5] PPP: Connection terminated.
2024-04-05 13:21:30 [5] PPP: Release PPP unit success
2024-04-05 13:21:30 [5] PPP: Modem hangup
2024-04-05 13:21:36 [5] System: DSL Link Down
2024-04-05 13:21:40 [5] System: DSL Training
2024-04-05 13:21:50 [5] System: DSL Link Down
2024-04-05 13:21:55 [5] System: DSL Training
2024-04-05 13:22:14 [5] System: DSL Link Down
2024-04-05 13:22:18 [5] System: DSL Training
2024-04-05 13:22:37 [5] System: DSL Link Up us/ds 216/9567 kbps Type ATM Annex A
2024-04-05 13:22:38 [6] PPP: PPPoATM pppoa_init
2024-04-05 13:22:38 [6] PPP: PPPoATM setdevname_pppoatm - SUCCESS:0.38
2024-04-05 13:22:38 [6] PPP: Using interface ppp1
2024-04-05 13:22:38 [5] PPP: Connect: ppp1 <--> 0.38
2024-04-05 13:22:44 [6] PPP: CHAP authentication succeeded
2024-04-05 13:22:44 [5] PPP: CHAP authentication succeeded
2024-04-05 13:22:45 [5] PPP: local IP address
2024-04-05 13:22:45 [5] PPP: remote IP address 195.166.130.249
2024-04-05 13:22:45 [5] PPP: primary DNS address 212.159.13.49
2024-04-05 13:22:45 [5] PPP: secondary DNS address 212.159.6.9
2024-04-05 13:25:21 [5] System: DSL Link Down
2024-04-05 13:25:21 [6] PPP: Terminating on signal 15
2024-04-05 13:25:21 [6] PPP: Connect time 2.7 minutes.
2024-04-05 13:25:21 [6] PPP: Sent 9908 bytes, received 17081 bytes.
2024-04-05 13:25:25 [6] PPP: Terminating on signal 15
2024-04-05 13:25:25 [5] System: DSL Training
2024-04-05 13:25:27 [5] PPP: Connection terminated.
2024-04-05 13:25:27 [5] PPP: Release PPP unit success
2024-04-05 13:25:27 [5] PPP: Modem hangup
2024-04-05 13:25:44 [5] System: DSL Link Down
2024-04-05 13:25:49 [5] System: DSL Training
2024-04-05 13:26:07 [5] System: DSL Link Up us/ds 888/9578 kbps Type ATM Annex A
2024-04-05 13:26:10 [6] PPP: PPPoATM pppoa_init
2024-04-05 13:26:10 [6] PPP: PPPoATM setdevname_pppoatm - SUCCESS:0.38
2024-04-05 13:26:10 [6] PPP: Using interface ppp1
2024-04-05 13:26:10 [5] PPP: Connect: ppp1 <--> 0.38
2024-04-05 13:26:12 [5] System: DSL Link Down
2024-04-05 13:26:16 [6] PPP: Terminating on signal 15
2024-04-05 13:26:16 [5] System: DSL Training
2024-04-05 13:26:20 [6] PPP: Terminating on signal 15
2024-04-05 13:26:22 [5] PPP: Connection terminated.
2024-04-05 13:26:22 [5] PPP: Release PPP unit success
2024-04-05 13:26:22 [5] PPP: Modem hangup
2024-04-05 13:26:35 [5] System: DSL Link Down
2024-04-05 13:26:40 [5] System: DSL Training
2024-04-05 13:26:58 [5] System: DSL Link Up us/ds 888/9597 kbps Type ATM Annex A
2024-04-05 13:26:59 [6] PPP: PPPoATM pppoa_init
2024-04-05 13:26:59 [6] PPP: PPPoATM setdevname_pppoatm - SUCCESS:0.38
2024-04-05 13:26:59 [6] PPP: Using interface ppp1
2024-04-05 13:26:59 [5] PPP: Connect: ppp1 <--> 0.38
2024-04-05 13:27:03 [5] System: DSL Link Down
2024-04-05 13:27:04 [6] PPP: Terminating on signal 15
2024-04-05 13:27:07 [5] System: DSL Training
2024-04-05 13:27:08 [6] PPP: Terminating on signal 15
2024-04-05 13:27:10 [5] PPP: Connection terminated.
2024-04-05 13:27:11 [5] PPP: Release PPP unit success
2024-04-05 13:27:11 [5] PPP: Modem hangup
2024-04-05 13:27:26 [5] System: DSL Link Down
2024-04-05 13:27:31 [5] System: DSL Training
2024-04-05 13:27:49 [5] System: DSL Link Up us/ds 256/9615 kbps Type ATM Annex A
2024-04-05 13:27:53 [6] PPP: PPPoATM pppoa_init
2024-04-05 13:27:53 [6] PPP: PPPoATM setdevname_pppoatm - SUCCESS:0.38
2024-04-05 13:27:53 [6] PPP: Using interface ppp1
2024-04-05 13:27:53 [5] PPP: Connect: ppp1 <--> 0.38
2024-04-05 13:27:54 [5] System: DSL Link Down
2024-04-05 13:27:58 [6] PPP: Terminating on signal 15
2024-04-05 13:27:59 [5] System: DSL Training
2024-04-05 13:28:02 [6] PPP: Terminating on signal 15
2024-04-05 13:28:04 [5] PPP: Connection terminated.
2024-04-05 13:28:05 [5] PPP: Release PPP unit success
2024-04-05 13:28:05 [5] PPP: Modem hangup
2024-04-05 13:28:09 [5] System: DSL Link Down
2024-04-05 13:28:13 [5] System: DSL Training
2024-04-05 13:28:32 [5] System: DSL Link Down
2024-04-05 13:28:37 [5] System: DSL Training
2024-04-05 13:28:55 [5] System: DSL Link Up us/ds 888/9578 kbps Type ATM Annex A
2024-04-05 13:28:57 [6] PPP: PPPoATM pppoa_init
2024-04-05 13:28:57 [6] PPP: PPPoATM setdevname_pppoatm - SUCCESS:0.38
2024-04-05 13:28:58 [6] PPP: Using interface ppp1
2024-04-05 13:28:58 [5] PPP: Connect: ppp1 <--> 0.38
2024-04-05 13:28:58 [6] PPP: CHAP authentication succeeded
2024-04-05 13:28:58 [5] PPP: CHAP authentication succeeded
2024-04-05 13:28:58 [5] PPP: local IP address
2024-04-05 13:28:58 [5] PPP: remote IP address 195.166.130.254
2024-04-05 13:28:58 [5] PPP: primary DNS address 212.159.13.49
2024-04-05 13:28:58 [5] PPP: secondary DNS address 212.159.6.9
05-04-2024 1:47 PM
OK, @Okay - It is fairly obvious from that there is a major problem somewhere. As @Dan_the_Van says, it could be your Master socket, but unless it is in a vulnerable location and gets knocked, I would be inclined to query that - personally. I suggest you check it is properly seated, just to make sure, but I am leaning towards something outside your environment being not right - that many xDSL drops in a short time is not acceptable.
05-04-2024 2:22 PM
Thank you John, I can't see anything obviously wrong with the master socket. The wires seem to be inserted firmly. It's not in a place that get's touched anyway.
What should I do now do you think?
Thanks.
