Broadband performance issues
- Broadband performance issues
30-04-2011 7:11 PM
did speed test. download is 013mbps!(ouch) and upload is 0.35mbps (which is normal)
Re: Broadband performance issues
01-05-2011 1:10 AM
Cant even sign into Xbox live its that bad
Whats going on ????
01-05-2011 12:43 PM
Down Up
18.03.11 Data Rate 2592KB 448Kb
Noise Margin 16db 23db
Attenuation 39db 22db
17.04.11 2944KB 448Kb
15db 23db
39db 22db
29.04.11 160KB 288KB
35db 6db
41db 23db
30.04.11 160KB 288KB
35db 6db
41db 23db
01.05.11 2880KB 448KB
15db 21db
40db 23db
All with newish Belkin Router which has never been switched off nor has it appeared to drop out. I do not have the advantage of a modern BT box with a test socket, the entry would have the disadvantage of being in the garage roof and nor handy fro checking that the connection was OK.
Looks as though there was some BT activity for a few days does it not? I know thatwe have just had the majorty of our overhead poles replaced carrying our connection over one and half KM to the exchange.
03-05-2011 10:37 AM
Are any of you still seeing these slow speeds?
Jojo
03-05-2011 12:53 PM
05-05-2011 10:26 AM
Still plodding along here, did you find out what had happened?
05-05-2011 11:09 AM
Speed check eventually gave less than 100k just now, but mostly it was just hanging.
I'm on pcl-ag02, but I think I had this problem on the previous connection yesterday, so it's probably more general.
05-05-2011 12:40 PM
05-05-2011 1:30 PM
There's no particular thing that I know of that will have caused that. If you are still seeing poor performance I would suggest starting a different thread with all the detail you can.
Jojo
05-05-2011 3:13 PM
Meanwhile, I phoned up the site I had most trouble with. Their immediate response was "Are you with Plusnet?"
As he added "We expect the problem to be sorted out within an hour" I shall hope this isn't going to need another thread.
I can now access the other sites that gave me "Not available" earlier this morning, such as BBC.
