Broadband not working
reid88
Hi, I reported an issue with our broadband on Saturday and I was told that they identified an issue and an engineer would be sent out on the same day. Since then I’ve had no response, I called on Sunday and they advised me that there’s no update. So I’m not entirely sure what is happening and when this will be fixed, everytime I call I just get a response of no update
2 REPLIES 2
Fixes: 241
Re: Broadband not working
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.  From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link.  NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
MatthewWheeler
Fixes: 503
Hi @reid88
I'm really sorry for how long it's taken to get back to you. We've been quite busy recently so it's taking longer than we'd like to reply.
I can't find any accounts with the details on your forum profile. Can you drop me a PM with your full address and postcode so I can try and locate the account that way?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
