Broadband not working
dahlia28
Have been unable to connect to internet for about 2 weeks.
Have completed all troubleshooting steps on website. Broadband light keeps flashing. So frustrated with this. Please help!
Gel
Seasoned Pro
Fixes: 12
Re: Broadband not working
Fixes: 21
A warm welcome to the forums.  Sorry to learn of your long standing problem.  What have you done so far?  Which router do you have?  Which lights (colour) is flashing?  What do you see when trying to access the internet?
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
If the above is OK, then double check through the speed issues thread (see link below) and then use the broadband fault reporter (link below).
Fixes: 149
Sorry to hear your connection isn't working.
If you raise this here we'll look into this.
 Matthew Wheeler
Fixes: 9
Difficult with no internet connection?  Can the fault be raised and investigated from the Plusnet end.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Fixes: 323
@MauriceC
We'd assume that being able to contact us via the internet, that they're able to raise a fault online.
@dahlia28
I've arranged for one of my colleagues to call you back after 4pm to help you out.
dahlia28
@Gandalf thank you. I followed the link provided above by @MatthewWheeler that takes me to the form to complete with contact details etc. I already completed this last week but wasn't contacted.
I am at work at the moment so don't know if calling me this afternoon will be of help if I am not with the router etc?
Fixes: 323
No worries, I've cancelled the call back as my colleague finishes shortly after 4.
From looking at your account, no fault has been raised. I can see where you've started the broadband troubleshooter but then closed it as resolved shortly after. Please can you spend a few minutes filling out the details again?
dahlia28
@Gandalf
Thanks. I have gone through the troubleshooting and tried with another microfilter. This seems to have worked,
Is it possible to send me a replacement microfilter? I have only managed to borrow one,
Eddddddddd
I just followed this link to the fault reporting site. Useful until it asked me to plug in a different router. Do many people have spare working routers set up to connect to Plusnet lying around waiting for a fault to develop? Because I don't.
I would really like Plusnet to provide me with the broadband service that I pay for and which was working fairly well until recently. I don't see why I should have to buy extra equipment just so you can fix it.
Fixes: 323
@dahlia28
Sorry for the delayed response.
I've just sent you a new microfilter now, we'll get it to you as soon as we can
@Eddddddddd
If you're not able to try a different router, I'd recommend trying the other steps of the troubleshooting.
dahlia28
@Gandalf
Thanks very much for your assistance. Much appreciated
Fixes: 323
No problems Smiley
