Broadband my way pro / line profile
- Broadband my way pro / line profile
09-05-2009 6:38 PM
Is it possible to request an engineer double check that I am on the right package? I ordered the pro package so I would have full speed (possible to my line) at all times, but I notice my DL speeds are slower, and my pings are higher at various times during the day.
I understand there are numerous factors at play here (I read the broadband speed article recommended) but as long as I know I'm getting the service I ordered and am paying for, then I'll at least be happy about that.
If this is possible, how do I go about requesting this double check?
PS. Just to give you an idea, my DL speed just now, as shown by the speed test on the member site, is a mere 585kbps.
Re: Can my IP profile be increased quickly?
09-05-2009 7:05 PM
I did do a search, but basic info was not forthcoming.
09-05-2009 7:28 PM
And then check your PN profile at the member centre https://portal.plus.net/my.html?action=data_transfer_speed (login required)
@mapletree
Very confusing, I've had to read 3 threads to get my head round this. All these issues are most likely related.
If I understood some earlier posts correctly, you've been monitoring your SNRM with RouterStats http://www.vwlowen.co.uk/internet/files.htm ?
It would be extremely helpful if you could post a current Noise Margin plot.
Are you absolutely certain that you haven't lost sync since the 7th (2200K+ reported in the OP) ?
This new cable that you've got, what is it exactly & how long is it?
09-05-2009 8:36 PM
The BT speedtester needs your phone number and the user name from your router e.g. XXX@plusdsl.net
Re: Broadband my way pro
09-05-2009 10:21 PM
09-05-2009 10:27 PM
10-05-2009 3:52 AM
Quote from: mapletree Are you on DSL max or a fixed sync rate? If you are not sure then ask PN or go to the member centre and select "Connection Settings" and then "High Speed Broadband". This should tell you the PN profile.
I don't know if I'm on DSL max or a fixed sync rate. Who / what is PN?
The results of that link show this:
Telephone number:
Phone exchange:
LEICESTER CENTRAL
Estimated line speed:
3.5 Mbps - Checked on 2009-02-11 00:20:03
Current line speed:
3500
10-05-2009 3:57 AM
Quote from: adiewoo Your PN profile can be found here https://portal.plus.net/my.html?action=data_transfer_speed
Thanks for the info
Another one - how do I find my router user name?
10-05-2009 8:07 AM
As you've started your own thread it would be better if we dealt with all you queries etc. there rather than hijack someone else's thread.
Re: Broadband my way pro / line profile
10-05-2009 8:38 AM
10-05-2009 9:26 AM
When you've run the BT Speedtester you will get your BT profile. Your PN profile that you got from the member centre (above) - misleadingly called line rate, determines your maximum possible throughput speed. This should be the same as the BT profile. Any change to the BT profile will be reflected in the PN profile usually within 12 hours. The throughput speed that you get from speed testers will always be less than the profile because of overheads, and can be considerably less at peak times if there is exchange or network congestion.
With the profile you've got, you are on maxDSL. You can get all the other information about your account by logging into the Member Centre.
Look at >Account details>Account Summary https://portal.plus.net/my.html?s=0&action=account_summary which will tell yoy about your product.
I suggest you have a good explore around the member centre, which can provide useful information and allow to control your account.
If you believe you have any line problems, we are going to need you to post your ADSL LInestats from your modem/router - the Sync speed (Line rate), Attenuation, SNRM (Noise Margin) Power for both Downstream (DS) and Upstream (US).
HTH.
11-05-2009 12:21 AM
I ran the BT test and indeed it gives the same potential line speed as my PN profile.
Unfortunately it also gives a similar actual DL speed as I stated before of under 600kbps. If it's just traffic / peak stuff then that's fine. My initial query was to just ensure that I was on the right package. I've had a good look about the member site and it does state that my package is My Way Pro, although does this prove I am getting this actual service? That might just be the administrative info.
I've looked at my router (the Thomson one which was supplied) and the only info I can find is as follows:
DSL Connection
Link Information
Uptime: 2 days, 23:08:05
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,224
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 54.0
SN Margin (Up/Down) [dB]: 20.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 50,131,684
CRC Errors (Up/Down): 0 / 819
HEC Errors (Up/Down): 0 / 732
Internet
Connection Information
Uptime: 2 days, 23:00:26
Data Transferred (Sent/Received) [MB/MB]: 73.05 / 453.34
Connection Settings
PVC Info (VPI.VCI): 0.38
Type: PPPoA
PPP Settings
Username: *******@*****
Password: ********
Connection Mode: Always-On
TCP/IP Settings
IP Address: **********
Default Gateway: 195.166.128.64
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
I'm not sure I can find "the Sync speed (Line rate), Attenuation, SNRM (Noise Margin) Power for both Downstream (DS) and Upstream (US)" I believe the modem is Thomson Gateway TG585 v7.
adie:blue IP address removed]
11-05-2009 12:59 AM
Quote from: gingle Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,224 (Sync Speed or Line Rate)
Output Power (Up/Down) [dBm]: 12.0 / 17.5 (Power)
Line Attenuation (Up/Down) [dB]: 31.5 / 54.0 (Attenuation)
SN Margin (Up/Down) [dB]: 20.0 / 6.5 (SNRM or SNR Margin or Noise Margin)
You've already given that information, just different terms for the same thing. I've marked the equivalent names in red in the quote. Down is Downstream, Up is Upstream.
David
11-05-2009 3:55 AM
adie:quote
11-05-2009 9:43 AM
You are getting far too many errors. Probably the automatic systems will increase your noise margin which should help a bit. However it would be a good idea to try and find the reason for the high error rate
Quote Uptime: 2 days, 23:08:05
