Broadband light flashing
- Broadband light flashing
08-01-2011 11:03 PM
Its been 53 days since i signed up to plusnet and i havnt been on the internet once.
any help.
Re: Broadband light flashing
08-01-2011 11:17 PM
08-01-2011 11:20 PM
08-01-2011 11:23 PM
It can take a day or two for a responce from support.
08-01-2011 11:27 PM
08-01-2011 11:31 PM
08-01-2011 11:35 PM
08-01-2011 11:38 PM
08-01-2011 11:40 PM
08-01-2011 11:46 PM
09-01-2011 2:37 AM
It seems likely the flashing light you mention is the "DSL" light, and means that the modem cannot synchronise with the DSL equipment in the BT exchange.
If the light stays like this, then that is pretty terminal - either your line is not activated at the exchange really, or your router just cannot hear the exchange.
Was the email reporting that your phone line was connected, or that your Broadband was connected? If you are having the two done together, then broadband activation takes a few extra days... although the router is generally posted out by PlusNet so that it arrives just before the Broadband is activated.
If it was telling you that your broadband that was activated, then you might be best served by phoning PN support, and get to talk to someone to confirmn activation: http://www.plus.net/support/customer_service/contact_us/contact_details.shtml says 0845 140 0200 for Residential Support, and 0845 140 0080 for Broadband & Telephone faults.
Otherwise, most fault-finding will start by suggesting a few standard steps, including plugging the modem into the test socket (behind the master socket faceplate) with everything else disconnected from the line. These steps are summarised at http://www.plus.net/support/broadband/bbfaults/noconnection.shtml, and can them jump into the online fault reporter at http://faults.plus.net/.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
09-01-2011 6:43 PM
I hope thats all it is for your sake - irritating but easily resolved with a little help from PN.
10-01-2011 1:07 PM
I see you've raised a question on your account but you need to answer the questions on faults.plus.net for our faults team to investigate this for you.
Jojo
