Broadband keeps failing
crypticmirror
I keep having my router default to the log into router page, when I log in I get this message:
No Broadband found.
Ensure your service is active. We'll email and text you when everything's ready.
Verify if your Technicolor Gateway is correctly connected to your DSL line. For more information consult your documentation.
Please close this window and try again.
This can last for up to an hour at a time, done all the usual things we're asked to do before calling regarding changing filters and turning the router off for ten minutes then on again. Nothing works. What is going on?
VileReynard
Seasoned Pro
Fixes: 9
Re: Broadband keeps failing
The router might be faulty.
If still in contract, you could ask for a replacement.
Plusnet Staff
Plusnet Staff
Fixes: 159
If you haven't done so yet, it's worth trying a factory reset of the router too.
Are you currently plugged in to the master socket? Is there any noise on the phone line?
 Chris Parr
 Plusnet Staff
