Broadband issues - Croydon
Richard77
Hi
Wi-Fi is down in Croydon. Any ideas on the fix time or best sites to check for updates
3 REPLIES 3
Fixes: 382
Re: Broadband issues - Croydon
@Richard77 Do you mean you currently have no internet connection, or the whole of Croydon is without it?
Richard77
Sorry - I don’t have any and from what I can see others in the area have the same issue
Fixes: 382
What is your dialling code? I suggest you (and others) report the issue to your ISP - in your case, follow the below:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
