Broadband intermittent
- Re: Broadband intermittent
10-07-2016 4:28 PM
Our boradband has gone intermittent again.
We've had no problems for about a year but it took us a long time to get the speeds we're paying for without it cutting out, last time we had this issue. Currently, it's likely to go offline at least once an hour for a few minutes. If someone could take a look that'd be good.
James
10-07-2016 4:38 PM
Hello. Sorry to hear that you're experiencing connection problems. I'll be happy to take a look at your account tomorrow morning for you when I'm back in the office. In the meantime, please could you run through the steps in our broadband trouble shooter at http://faults.plus.net to see if it helps resolve the problem?
(I'd also suggest running a line test yourself at https://portal.plus.net/my-account/tools/phone-troubleshooter/ just to make sure there are no issues with the line itself)
10-07-2016 4:47 PM
Hi Anoush, this is what I see, upon clicking the link you provided.....
10-07-2016 4:49 PM
Hmm, I've managed to replicate that issue if I click on it whilst not logged in to the Member Centre. Can you try logging in first (if you haven't already)?
10-07-2016 5:01 PM - edited 10-07-2016 5:16 PM
Ahhhh, it needed me to be logged in first....
But......Something has gone wrong .....
My choices were Other & inputed, some incoming calls, knock my broadband off.....
Save
10-07-2016 5:06 PM
Thanks Anoush,
I filled out the form thingy as best I could but we don't have a phone so it's hard to give a proper answer to any of it without replacing all our hardware. Last time it was resolvable by Plusnet adjusting our bandwidth.
10-07-2016 5:15 PM
No problem and thanks, James. It's possible that we can just do that again, I'll pick up your ticket tomorrow morning.
@Welshdragon I have seen that message before. In a previous instance, the phone trouble shooter found a fault, opened a ticket on the account, and raised the issue to Openreach. Can you check for any open tickets at https://www.plus.net/wizard/?p=search If there isn't a relevant ticket I'll look into your account tomorrow morning also.
10-07-2016 5:21 PM
Hi Anoush
I will start a new thread titled Workplace profile was mismatched and has been updated
11-07-2016 9:07 AM
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 12.6 | 25.0 |
SNR Margin: | 14.5 | 12.1 |
Errored Seconds: | 0 | 2 |
HEC Errors: | 0 | |
Cell Count: | 424 | 1431 |
Speed: | 472 | 13547 |
@jamesl182d Thanks for your patience. Your connection is quite intermittent and the SNR margin has risen too high in an effort to stabilise it. From looking at your fault notes, the issue appears to either be your router or the line outside. We would need to arrange an engineer appointment, however if the fault is the router there may be a possible callout charge.
If you would like to try a different one first we can look into providing you a replacement on a new contract/perhaps a better deal than what you are currently paying if you call our customer options team on 0800 013 2632. Alternatively, if you would like to proceed with an engineer please could you complete the broadband troubleshooter?
