turn on suggestions
Broadband has been active since 2nd Feb, routers still not detecting DSL
- Broadband has been active since 2nd Feb, routers s...
06-02-2012 3:57 PM
I've tried with three separate routers, all of which I tested with another connection so I know they definitely work, I have also tried different filters, different cables, plugged the routers directly into the master socket with nothing else in the house plugged in and still the DSL light does not come on with any of the routers.
Raised a ticket, and one of the reponses was;
[Internal]
RADIUS: Not connected
TAGS ok
NSC
NIC ok
CLT ok
TAM : DNR
Does anyone have any idea what this means? They want to send an engineer out who I assume will do all the same things that I have already tried....
Cheers.
[Internal]
TAGS ok
NSC
NIC ok
CLT ok
TAM : DNR
Cheers.
Re: Broadband has been active since 2nd Feb, routers still not detecting DSL
06-02-2012 5:38 PM
06-02-2012 5:48 PM
Thanks Chris. Any idea what the [Internal] stuff means?
06-02-2012 6:48 PM
RADIUS is the Remote Access Dial In User Server, and that says you are not connected.
TAM is Test Access Matrix (a testing device) and I assume DNR is Did Not Respond.
Both of these, not surprisingly, confirm no evidence of a connection, and engineer attention is needed to establish why and fix the fault.
David
06-02-2012 6:58 PM
Nice one, cheers for that info mate.
