Broadband frequently dropping
DrumLust
Hi, my broadband connection has been dropping out multiple times a day, mulitple times an hour at its worst.  Have been experiencing this for the past few days or so.  When the connection drops, the router light changes from blue to red, then amber flashing until it reconnects.
Some help with this issue would be greatly appreciated!  😅
3 REPLIES 3
Fixes: 334
Re: Broadband frequently dropping
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
DrumLust
Thank you for the speedy reply.  I do not have a phone service, it is broadband only so reporting by text message doesn't work unfortunately.
Fixes: 334
OK. I am now aware that this suggested course of action doesn't work for SOGEA connections such as yours. All you can do is call the fault in via phone (0330 123 9123). Thanks for reminding me I need to change the wording on that  message.
