Broadband extremely slow downloading apps from Google Play Store
FIXED- Subscribe to RSS Feed
- Broadband extremely slow downloading apps from Goo...
05-03-2020 8:44 AM
I have a 2704n router for my plusnet broadband service. My download speed (from ookla is about 4Mbps with which I'm quite happy
However, if I try to download apps from the Google Play store on my phone the speed is incredibly slow. It takes over half an hour to download a small (a few MB) update to an app. I don't think the problem lies with my phone as the updates run fine connected to the WiFi in the local pub.
I have tried changing my DNS servers on the router to use the Google Ones, but with little success.
Any ideas on solving this problem before I get in touch with Tech Supoort would be gratefully received.
Fixed! Go to the fix.
Re: Broadband extremely slow downloading apps from Google Play Store
07-03-2020 10:38 AM
I tried a different router but same issue however I also tried my brothers EE wifi and no issue at all so as above the issue seems to be at the Plusnet side...
12-03-2020 9:37 AM
Hi @tkdfan
Thank you for your query!
This one does sound a little odd. However, to try and help resolve the problem I have added a static IP to your account. If I could ask that you please reset your router and then monitor the situation.
In addition, I would also try (if you haven't already done so) splitting the frequencies as per our router guides. Further information on how to do this can be found here. I'd test both the 2.4Ghz and 5Ghz option, although some devices are not compatible with the 5Ghz.
Please do let us know how you get on!
12-03-2020 11:20 AM
Hi KatieC,
Thanks for your efforts in resolving the problem with my slow Google Play downloads.
I have reset my router as requested, and you'l be glad to hear that it does seem to have fixed the problem.
Regards,
Andrew
12-03-2020 11:31 AM
Thank you for the update @tkdfan
I'm pleased to hear that your query is now resolved. Please do let us know if you have any further problems!
