Broadband drops out multiple times a day
- Broadband drops out multiple times a day
15-07-2018 8:35 PM
I have tried resetting the router but in the last few days my Plusnet broadband repeatedly drops out.
we also receive error messages on many webpages asking us to reload the page.
I have only been a customer two weeks and everything seemed fine for the first ten days or so.
Re: Broadband drops out multiple times a day
15-07-2018 11:20 PM
Have you tried following the help Guide online? https://www.plus.net/help/broadband/connection-troubleshooting/
With this being a new connection its possible it may just be DLM(dynamic line management) acting on the line and may stabilize. I would strongly recommend you follow the guide tho as it will be a big help
Thanks, R
16-07-2018 10:14 AM - edited 16-07-2018 10:17 AM
Hi @samdoubtfire,
I'm sorry to hear that your connection has been dropping. I've tested your line and the test isn't picking up the cause of this issue:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.3 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 410.2 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 08:30 to 08:45 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-07-03T11:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 62.7 Mbps | 80.0 Mbps | 77.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 802.0 Sec | 900.0 Sec | 898.3 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-07-16T08:37:39Z | 2018-07-16T08:52:39Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 371 | 0 |
However, I can see from your connection logs that it has been dropping frequently:
I'd recommend that you run through the troubleshooting guide that @MrPowell has linked to above. If the troubleshooting checks don't resolve the problem, please report the issue here and let us know when you've completed it.
22-07-2018 10:45 PM
This is still an ongoing problem, please can someone help. I was told 72 hours!!
23-07-2018 11:42 AM
23-07-2018 4:19 PM
23-07-2018 4:20 PM
23-07-2018 5:04 PM
Hi @samdoubtfire,
I'm sorry for the length of time that the dropping connection issue has been ongoing for and for the inconvenience that this is causing you.
My colleague has raised this to our products team to request that they push the latest firmware update to your router to try and resolve this issue. Unfortunately, this team doesn't have a set lead time but they normally respond to our requests within 24-48 hours.
We will be back in touch once we have heard from the products team and if this issue persists once the firmware update has been pushed through, we will investigate this further for you.
