Broadband drops for no reason
- Re: Broadband drops for no reason
17-05-2020 3:31 PM
I have been having this problem for a few weeks now. Broadband drops, then waits 10 minutes or so and restarts again. I have done all the checks that Plusnet ask, even changed to my old router for a few days, but the same thing happened with that one. It will be ok for a few days or so, then for no reason, drops.
Anyone have any idea why this happens. I'm not on Twitter, can't chat with the Helpdesk as I don't get the option, and I am definitely not phoning them as I don't want to waste half of my day hanging on a phone.
18-05-2020 1:55 PM
@AllanJ Sorry to hear of the issues you're having.
So that we can look at this and offer the correct guidance please send us a private message with the account username.
Thanks - Carl.
19-05-2020 5:57 PM
So, after giving my account name by private message, how long do you have to wait for anything to happen? I was kicked out of a very important zoom conference last night at 7:43pm because of this, and again, just 20 minutes ago it just dropped for 10 minutes.
19-05-2020 6:43 PM
@AllanJ I've checked the connection this side and it looks like the signal strength for your line is set too low which explains when your devices seem connected but nothing loads up or you just get buffing.
The good news is it's a fairly easy fix and I have placed an order to up your signal strength which should complete in the next hour. If you then turn the router off and then on again in a hour or later the connection should be back to normal
19-05-2020 7:05 PM
Thanks. I will do that and see how it goes in the next couple of days.
23-05-2020 3:34 PM
Hi
My internet just dropped again for 10 minutes. This is getting quite serious. I have quite important conference calls coming up next week and I need to be assured I have an Internet connection.
Same as before. Just disconnects for no reason, then boots up again.
If Plusnet believe the problem is at my end, then could Plusnet send me a new router and micro filters, and please don't try and bill me for them. The ones I am using are the same ones you gave me when I signed this contract more than 18 months ago.
You already have my account name.
Signed
A very distressed person
25-05-2020 7:50 PM
And again. In the middle of a conference call.
When Vodafone get connected in this area, I will definitely be switching over to them. Too many problems with Plusnet this last year.
26-05-2020 11:51 AM
We need to start with the basics. I note you've only contacted us on social media and haven't raised any fault report so I'm presuming all the information we have is here. We've made a change which may or may not have worked temporarily.
Your connection looks like this.,..
Before we do anything else, we need to rule out your side.
Do you agree that the line drops at those times? If you're seeing more drops, I suspect this is a different issue altogether (Wi-Fi or lack of data transfer) and if it is, I don't want to waste your time with diagnostics that won't help.
If you are seeing those, as above, and "SNR" (Signal to noise) increase or switching 'interleaving' on can help.
However, as I said at the start of this message, let's start with the basics.
Is your phone in working order? Does it have a dial tone etc?
Have you plugged your router into your test socket without any other devices plugged in? If not, please do so now and we'll see if it drops whilst plugged in there.
Have you tested another router?
These are standard diagnostics used by all ISP's using the Openreach network.
If you further information on finding and testing in the master and test socket, please let us know and we can advise further.
26-05-2020 3:45 PM
Hi Plusnettony
My apologies for sounding a bit grumpy. I think this lockdown is starting to get to me.
However, Yes, I agree with the diagram showing my lost connection, although Friday I rebooted a few times and plugged into the test socket on the master socket. (That was a different problem of all lights, but no internet). The router has been plugged into the test socket ever since.
Phone line is ok. perfect dial tone. I have changed micro filters and went back to my old router for a few days. Still the same. Now back to my Sagemcom that you gave me when I took out this contract.
Interesting that it hasn't went down anytime today, yet. Hopefully your little change has fixed it.
Regarding the fault report, could you tell me how to raise a fault report on the website.
Allanj
27-05-2020 10:31 AM
27-05-2020 10:58 AM
Thanks willf. I will let you know if anything starts going wonky again through the proper channel now.
Allanj
02-06-2020 3:29 PM
Hi Plusnet team
Whatever you did seems to have solved the problem. Thank you. No noticeable drops all week.
So, is it safe now to take the router connection out of the test socket and replace the cover, or should I play safe and leave it as it is.
Allanj
