Broadband dropping multiple times a day (hub 2)
Liviop
Wi-Fi has been perfectly fine but over the last couple of days it seems to drop out fairly frequently, 5-6 times a day at the worst of it.
The hub seems to turn orange for around 30 seconds then turns blue again.
Not sure what seems to be causing it I have tried resetting the router but not sure if it’s an issue on my end or anything else.
Would really appreciate any help as with working from home I don’t want to be dropping out in any teams meetings.
Many thanks
2 REPLIES 2
Fixes: 306
Re: Broadband dropping multiple times a day (hub 2)
@Liviop :
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Liviop
Hi John thanks for getting back to me, I have just internet only so I have used that link to report the problem.
Smiley many thanks
