Broadband dropped from 40Mb to 1Mb
Daveodeth
Hi
I'm a fibre customer and have seen a massive drop over the last few days, have a ticket open with plusnet as well it's always good to ask around.
speed for the last few days has shown the below
I have used the bt speedtest as well twice so far and it shows roughly the same as below for both
Download speedachieved during the test was - 1.2 Mbps
For your connection, the acceptable range of speedsis 31.59 Mbps-39.49 Mbps .
Additional Information:
IP Profile for your line is - 39.49 Mbps
Upload speed achieved during the test was - 0.01Mbps
Am I missing something my end or does that look wrong? This was by ethernet connect by the way
Edit: also used multiple machines in the house to make sure it wasn't on the fritz but they all came back the same.
thesawdust
Re: Broadband dropped from 40Mb to 1Mb
try a gateway hop, i was on a gateway (ptw-ag01) this morning giving me really poor speeds (1-5mb)
Daveodeth
Quote from: thesawdust
try a gateway hop, i was on a gateway (ptn-ag01) this morning giving me really poor speeds (1-5mb)
God damn son you hit the mark, much obliged.
thesawdust
No Problems, Glad to see it resolved it  Wink
Also, by any chance did you know what gateway you was connected to prior to the hop?  Smiley
Daveodeth
Unfortunately not, I do know I am not on ag04 now though and it is back to how it should be.
thesawdust
it's ptw-ag01 that's having problems. I've just gateway hopped and was on this gateway and was pulling 172kb/s  Shocked
Fixes: 5
What exchanges are you on?
Kelly Dorset
Broadband Service Manager
thesawdust
I'm on Lymington, always see a raise in pings during peak hours. Not really a speed issue though, that i'm aware of anyhow  Smiley
ScottJames
So how do you go about doing a gateway hop?
Thanks  Smiley
thesawdust
login to router click disconnect, wait 60seconds and click connect again  Wink
Plusnet Staff
Plusnet Staff
Fixes: 5
Please let us know if you have any further problems and let us know what gateway you were on wen the problem came to your attention.
Chris Pettitt
Cloud Environments Engineer
Fixes: 5
I think we've replicated the issue on PTW-AG01.  We're looking at it.
Kelly Dorset
Daveodeth
Quote from: Kelly
I am on the nuneaton exchange
