Broadband dropout
- Broadband dropout
Re: Broadband dropout
15-11-2007 8:49 AM
Unfortunately the fact that you have an intermittent fault, even though it worked for a few hours, does not prove that the modem itself is not at fault.
I've now raised your fault with BT and we'll be able to update you further once we have heard back from them.
15-11-2007 9:11 AM
15-11-2007 2:25 PM
Quote from: suesykes This is exactly whats happening to me... I have just borrowed another router to see if it fixes the problem.
I'm really not happy with this at all
15-11-2007 2:28 PM
15-11-2007 2:40 PM
As mentioned on the phone just now, I would expect some form of update from BT in the next 12 hours.
15-11-2007 4:42 PM
16-11-2007 9:10 AM
for added information.
Last evenining from 1800 when arrived home. Modem showing Power Green. DSL flashing all the time no other lights on. Tried the usual unplugging connecting only PC to master socket etc. All the same. At 2052 all lights came on and system started working - all evening.
Deliberately left the modem on during the night. This morning all lights on but no connection albeit the system showed first of all "full connection" and then "This connection has limited or no connectivity - You might not be able to access internet" - this was 0730 this morning - so nothing again
16-11-2007 9:15 AM
Thanks for that. I'm just trying to get some further information back from BT. I'll update your ticket.
16-11-2007 3:53 PM
If & when this is sorted I will be the first to congratulate you I assure you and put it on the site.
19-11-2007 8:49 AM
spent a number of hours on the phone with Steve on Sat night. He talked me through setting up the Router as wasn't aware there was nio disk wetc with it. Managed to get working but found that if speaking on the phone - it worked. Switched phone off it dropped out. All details on my ticket. Got BT they advised line OK (I Realise this is merely the phone line).
It is till the same. In order to send some important e mails we kept switching the phone on which brings broadband back on but annoying when BT send the blast down the line to tell you your phone is off the hook !!!.
19-11-2007 9:09 AM
Would you mind trying to swap the microfilter again, now that you have managed to get the router working fine? The problem that you are experiencing is often a result of a poor filter interfering between the analogue and digital signals coming down your phone line.
19-11-2007 9:14 AM
19-11-2007 9:15 AM
Do you get the same problem when you are connected to the test socket behind the master faceplate?
19-11-2007 9:27 AM
19-11-2007 9:36 AM
I guess you phoned BT on 150? Which would have been Retail, which would have been the advice that I would have given.
We're still waiting back on Wholesale to give us an update, although this could have been slowed by any fault that you made with Retail. Hopefully we should hear back by this afternoon. Feel free to give me a prod if I haven't remembered and I'll be more than happy to chase for an update then.
