Broadband download speed - When will it recover?
- Broadband download speed - When will it recover?
- « Previous
- Next »
Re: Broadband download speed - When will it recover?
30-09-2011 5:03 PM
I am using a Netgear Wireless N ADSL2 + modem router model no. DGN2000 attached to my main computer by ethernet cable.
The good news is that my download speeds have now gone back up to about 1300 kbps, which is near the maximum! I am not sure why, but happy if it stays that way.
Simon
30-09-2011 6:11 PM
Just one of life's little mysteries, I guess...
03-11-2011 7:12 AM
Can anyone help again please with a reduction in my broadband download speed (now about 900 kbps download, 350 kbps upload)? The speed has dropped from about 1,300 kbps to 1the current level over a period of a few weeks (since my last reported problem at the end of September), but most notably yesterday.
I have attached my current modem stats for info.
Kind regards
Simon
03-11-2011 10:59 AM
You've been connected for over 7 days at this rate. I'd say to reboot in order to get a better sync rate. Most would advise to do this during daylight hours.
Jojo
04-11-2011 6:22 AM
I have rebooted my router this morning and the modem stats are showing a big increase in the connection speed (downstream) compared to yesterday. However, I am getting about 700 kbps from a speed check, which is slower than before. Would you expect this to recover now over a period of time?
Simon
04-11-2011 6:24 AM
Simon
04-11-2011 10:05 AM
Delta report is still at 750 unfortunately and the profile on our side is set to match. That should indeed uplift though it'd be worth resyncing the router on a daily basis (ideally around lunchtime) to help it along.
04-11-2011 12:58 PM
Thanks for the update. Just to check that I should restart my router every lunchtime until the speed recovers - it that correct?
Regards
Simon
04-11-2011 1:17 PM
04-11-2011 11:49 PM
Just to report that, having rebooted the modem at around 1pm today, my download speed this evening has recovered to >1.5 Mbps, which is great for this line!
As there have been several instances where the speed has dropped (evidenced by this thread), would you suggest that I should use this approach every time, or are there situations where rebooting can make the situation worse?
Many thanks
Simon
07-11-2011 10:51 AM
one reboot a day shouldn't cause any problems but more than that could. How is it today?
Jojo
07-11-2011 10:53 AM
- « Previous
- Next »
