Broadband down
Sselby123
Broadband down
Broadband has just completely down this morning is there a reason why do you know? I see down detector show a few people in the same boat
24 REPLIES 24
Simba42
Re: Broadband down
Same boat here..
and https://plusnet.servicestatus.net/ seems to be down too.. so you can't check service status
Champnet
Aspiring Hero
Fixes: 16
Re: Broadband down
We had the same problem but all working now. Suspect it was either a DNS slow response problem or exceptionally high Internet traffic.
RichT
Re: Broadband down
I see several thousand people have reported complete breakdown of PlusNet services on DownDetector.
Sselby123
Re: Broadband down
I'm still down
flip1
Re: Broadband down
We are down too - blue light on but no service 😡 seems like a problem for many
bengutt
Re: Broadband down
I'm still down too. Looks like a dhcp issue as my router is connecting but it has been given a private 10. Address.
jamesgibby
Re: Broadband down
Down too, would be nice if Plusnet communicated why and a likely ETA for a fix.
Bucketinabag
Re: Broadband down
Yeah, some communication would be nice! Still down here too
Alex
Fixes: 13
Re: Broadband down
Seen a couple of threads on this .. I will check my PlusNet connection a bit later.
Any noise on the landline?
Just wondering if it could be congestion as the networks may be busy at the moment.
Sselby123
Re: Broadband down
Land line absolutely fine, no noise. Broadband just cut out and hasn't returned since like probably a lot of others
Alex
Fixes: 13
Re: Broadband down
Ok I am wondering if there is a major outage and you all live in a similar area.
I don't think there is a problem with our connection or I'll hear about it. Sorry that sounds arrogant and rude, I don't mean it to come across that way.
Sselby123
Re: Broadband down
I'm Devon and a few people in my are haven't got Internet either, it looks like a major outage. Down detector has thousands of reports all over the uk
Sselby123
Re: Broadband down
I have a ip address 10 which isn't right
jamesgibby
Re: Broadband down
Norwich, work I IT, normally work from home fortunately on holiday today.
Line is fine used the Plusnet text service and it texted back.
Have a high quality router which was working fine then the internet went down. Not come back up since.
Restarted the router multiple times, pretty sure it is a Plusnet outage of some sort
