Broadband down, and 4 hours trying to get throught to support
- Re: Broadband down, and 4 hours trying to get thro...
01-02-2014 6:10 PM
I am very unhappy. My broadband has gone from 4mbs to 0.15mbs ( tested on the bt wholesale speed tester). Just to add to my annoyance, I have been trying for four hours to speak top someone in customer support. I've never had such bad service, and I will be changing supplier. This is worse than BT!
Message 1 of 6
(796 Views)
5 REPLIES 5
Re: Broadband down, and 4 hours trying to get throught to support
01-02-2014 6:26 PM
Have you raised a fault at http://faults.plus.net ?
Message 2 of 6
(473 Views)
01-02-2014 6:30 PM
Yes, 5 hours ago, and nothing.................................really unimpressed.
Message 3 of 6
(473 Views)
01-02-2014 6:43 PM
Have you rebooted your router?
Geoff,
York.
York.
Message 4 of 6
(473 Views)
01-02-2014 7:34 PM
rebooted, changed filters, changed routers. I'm an ex Openreach engineer, the fault is e side.
Message 5 of 6
(473 Views)
01-02-2014 8:04 PM
As you know fault is in the E-side I'd guess you have put a TDR or equivalent instrument on the line to measure the distance to the fault from your house.
As you still have broadband albeit very poor indeed I'd guess it is 'single line dis' fault then as BB can function (very badly) on just one wire of the line pair.
Message 6 of 6
(473 Views)
