Broadband down. Can't see how new router will help.
Fixes: 235
Re: Broadband down. Can't see how new router will help.
@jab1 wrote:
I have connected the router to the primary socket and it is flashing orange.
@Townman  No sync?
Check you router lights
Your router lights can tell you a great deal about what is happening when things are not as they should be. The colour of the lights and their state will tell you all you need to know ... if only you could find the help sheet which came with the router. That information can also be found in the depths of the on-line help & support guides. The following links make the material easier to find.
Yup!  Just like the BT Modem reported no xDSL signal.
Self help diagnostics with a simple thing as a telephone handset can save hours or days of stand off arising from not being able to listen to the line ...
Try running the Broadband fault bot - see the link below - just need a mobile phone to send a text ...
bobw1943
It was after seeing that same message on my tablet this morning that I had the conversation with the engineer.
I just tried an older router but no joy. I can't see beyond the lack of aDSL light on the modem. I don't have access to a "land" phone.
Fixes: 334
@bobw1943 Double/triple check all your cables are fully seated and not damaged in any way. If they are, then, IMVHO, this is an external problem which needs PN investigation, as intimated by @Townman  above.
bobw1943
Cables all appear fine, I've connected and reconnected. The router is back in it's usual spot and it is steady orange.
Fixes: 334
Do you mean the BT modem is back in the mix, or have you left it out?
bobw1943
It's back. Got to go out no.w
Fixes: 334
Is it really needed - how much extra length dies it actually give you? It is just an added point of potential failure.
Fixes: 123
If the Hub Two is connected to a modem which is turned on it will be using the WAN port the light will be solid orange when there the modem has a DSL link down fault. The Hub detects a Ethernet connection but can not make a successful PPPoE connection, so it reports 'something is wrong'
If the Hub Two has NO DSL or WAN physical connection the light will flash orange
bobw1943
Point is that having connected the router direct to the primary socket the modem is eliminated as the source of this problem.
bobw1943
The router is steady orange.
Fixes: 334
Agreed, but unless the extra cable length is essential, it merely introduces an unnecessary point of failure.
LexLex2020
Fixes: 12
@bobw1943 Hi!
Thanks for taking my call, as discussed I will be calling you back later today to go through some quick checks, then we can look at raising this further.
Is 4:30 pm still okay with you?
Regards,
Lex
@Townman Cheers for notifying us.  Highly doubt it is the router at fault, testing is showing that there is a potential for router setup, if not send it right to Openreach.
When I speak to bobw1943 later today I will update here again with the outcome.
Lex Keehner
bobw1943
Just got home, so 4.30 is fine
LexLex2020
Fixes: 12
As discussed over the phone, the appointment is now all booked in and I have sent you confirmation of this via text and email.
Have a good day!
Lex
Lex Keehner
Fixes: 334
@LexLex2020 Only because I'm a curios individual 😀, but is there anything of the issues behind this you can share?
