Broadband disconnects - If I'm in a call then it reconnects
- Broadband disconnects - If I'm in a call then it r...
24-11-2010 12:20 AM
I would like to know if someone can help here.
I've been thru this already with Plusnet. They even sent the BT guy to check the quality of my line. (Good quality in all tests).
Now I'm back to sqaure one.
Router looses connectivity. keeps trying to sync.
Then I make a phone call from my landline to a dumb number (any number) and then Router syncs and broadband connection on again.
If I drop the call, then broadband connection drops.
Anyone?
Have tried with Plusnet router and my own D-link router, same behaviour.
Any input appreciated.
Cheers!
D
PS: Next step is to move back to BT is this really annoying situation continues.
Re: Broadband disconnects - If I'm in a call then it reconnects
24-11-2010 12:52 AM
24-11-2010 7:56 AM
Have tried different filters. I have tried with different routers, different phones and different filters. (Following the instructions from Plusnet support). I am using only the master socket downstairs, one phone and the router connected to it. The issue is that I just spent 3 or 4 weeks of stable connection and suddenly last night the problem started again. In case it is an issue with a filter then why it happens in such a sporadic / irregular way?
I do not have Sky at home, only have an alarm, but again,in order to discard the alarm, when I got disconnected last night I connected the router directly to the main socket (by-passing the alarm) just as the BT technician recommended. To my surprise the problem continued. So, it is not the alarm (which I've had for 4 years now, and for the record, the problems started as I moved to Plusnet 6 months ago...)
So, the problem is irregular, have tried several filters, no sky at home and it is not the alarm. For example this morning I'm not in a phone call and my router is connected and working ok-ish.
Didn't touch it since last night, it got sync'ed and broadband is working. Right now I have 160 Kbps Upstream, 3424 Kbps Downstream. Upstream is on the slow side (usually get 400+) and downstream is the maximum I can get.
The funny/weird thing is that I know that if the router gets disconnected (does not sync), I just make a call and then router re-syncs. Problem is I need to stay int he call for it to work... I believe it is on the plusnet side, but so far, I have no way to prove it...
24-11-2010 8:14 AM
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 160
Downstream Rate (Kbps) 3424
US Margin 7
DS Margin 9
Modulation GDMT
LOS Errors 0
DS Line Attenuation 55
US Line Attenuation 63
Path Mode Interleaved
24-11-2010 8:23 AM
Quote ~ adsl only works when the phone is being used.
* Check filters and internal wiring.
* Check for noise on the line which may help identify the problem by doing a "quiet line test".
(Dial 17070 and select option 2).
* If so - Possibly a fault on the actual phone line perhaps due to worn cables or water on the line.
There may be times when a cable or joint is only slightly damaged/corroded and shows no immediate problem, however the damage is sufficient to increase resistance on the line.
When the phone line is in use, it generates a small electrical current which is needed to carry the voice signal. This current helps reduce resistance on the line and can be sufficient to "bridge the gap" just enough to carry the adsl signal. This is known as a High Open or High Resistance Fault.
24-11-2010 9:19 AM
Will try what you recommend, I noticed that when the connection drops and the modem cannot sync there is a lot of noise on my phone line - scratching noises, sometimes it gets really bad. (which is the reason why plusnet sent the BT techy to do a line test). Unforthunately when the BT techy was here, Murphy's Law hit, and everything worked perfectly, no noise in the line and all tests perfect... 😞
Right now things seem to have stabilized, if I hear the noises again and my connection drops I will perform the test you propose.
24-11-2010 9:57 AM
Quote DS Line Attenuation 55
That indicates a definite problem, the upstream attenuation is normally about 1/2 that of the downstream since it uses lower frequencies. The fact that yours is higher than the downstream indicates a problem and explains the low upstream synch.
24-11-2010 10:29 AM
Quote That indicates a definite problem, the upstream attenuation is normally about 1/2 that of the downstream since it uses lower frequencies. The fact that yours is higher than the downstream indicates a problem and explains the low upstream synch.
So what can I do here? Any next steps? Who's fault is this?
Broadband connection has been on, however I did the "quiet line test" and what I could hear was all the noise/scratching that happens on my line... crazy!
24-11-2010 11:11 AM
24-11-2010 11:29 AM
I just opened a support ticket with Plusnet support and provided them the link to this forum topic.
Broadband is again dropping... I'm connected using the trick of making a phone call...
Found this site that details a bit more the "High Open" issue you raise: http://www.dslreports.com/faq/11821
24-11-2010 12:20 PM
24-11-2010 12:31 PM
Phone and Broadband with Plusnet.
24-11-2010 2:17 PM
If you dial 17070 option 1 is a ring back test - let it ring a good few times.
24-11-2010 2:19 PM
Quote from: dmi Unforthunately when the BT techy was here, Murphy's Law hit, and everything worked perfectly, no noise in the line and all tests perfect... 😞
If the ringing of an incoming makes a temporary improvement, did he give you a call to say he was on his way?
24-11-2010 4:19 PM
Quote Have you checked if the ringing of an incoming call helps? That uses a higher voltage I believe which can further improve poor joints.
Difficult to say cause I need to make the call to 17070 (which enables the connection for a few secs)...
Quote did he give you a call to say he was on his way?
What do you mean?
