Broadband disconnections
- Broadband disconnections
27-01-2012 4:58 PM
I got a problems with my connection its suddenly drops 20-30 times per day, i have Pro Add On but i cant play any games, big lattency, ddrops out mb i do something wrong?
regards,
diana
Re: Broadband disconnections
27-01-2012 5:02 PM
Sorry to hear about this. I'd advise taking a look at the faults troubleshooter here: http://faults.plus.net/ this will guide you through some basic checks first which are intended to help us rule out anything in your domain that might be a cause of the issue. Beyond that if there's still issues we can look at raising the issue with our suppliers. Either way I'm sure we can help you get this nipped in the bud.
27-01-2012 11:56 PM
28-01-2012 7:25 PM
However, the only way I can resolve this each time it drops it is to wait until the Broadband light starts to flash, then rapidly and repeatedly press down on the button under the cradle on my phone until the Broadband light goes solid and the red Internet light goes on before turning to green.
I am therefore thinking this may be a problem with the phone line itself rather than a router/broadband problem - anyone else experienced this?
30-01-2012 3:08 PM
I see you started to raise a fault, but I would advise you to go back an complete the questions so that the faults team can start testing.
Jojo
broadband speed
02-02-2012 5:05 PM
i have some problems with my broadband (not with router),when i start using plus.net broadband my download speed was 8-9 mbps not bad, very good, i was really happy with it BUT, since 1.02.2012 i got a trouble my speed falls down and know at the best time i have only 4 mb per second , speed was cut on it half May be it is possible to get my speed back to 8mb?
02-02-2012 5:19 PM
Are you still getting multiple disconnections.
Can you post the information requested here as it may help explain what has happened http://community.plus.net/forum/index.php/topic,96155.0.html
02-02-2012 5:33 PM
here is details from speedtest.net
http://www.speedtest.net/results.php?hd=01/25/2012&s=0
02-02-2012 5:51 PM
Quote from: diana86 Hi,
regards,
diana
It is very likely that due to all those disconnections the default noise margin has been raised.
if you post the information requested we may have a better idea
02-02-2012 6:04 PM
here is details about my DSL
DSL synchronization status Up
DSL up time 1 Days 08:47:37
Line Status
Help
Upstream line rate (kbit/s) 444
Downstream line rate (kbit/s) 4544
Line standard ADSL2+
Channel type Interleaved
Upstream SNR (dB) 23.8
Downstream SNR (dB) 6.1
Upstream interleave depth 1
Downstream interleave depth 352
Upstream line attenuation (dB) 15.3
Downstream line attenuation (dB) 32
Upstream output power (dBmV) 11.5
Downstream output power (dBmV) 0
Upstream CRC 50117
Downstream CRC 0
Upstream FEC 8007
Downstream FEC 0
in second row, you can see that DSL up time is 1 day 08:47:37 , it looks that you change my line profile 32 hours ago, (01.02.2012) and my speed breaks down since this date can you return my old line profile please?
02-02-2012 6:08 PM
Did you raise a fault as previously recommended
02-02-2012 6:25 PM
02-02-2012 6:36 PM
Do you have the router connected to the master socket or to an extension
02-02-2012 6:40 PM
02-02-2012 6:44 PM
