Broadband cutting out and slower speeds since this morning
FIXED- Subscribe to RSS Feed
- Broadband cutting out and slower speeds since this...
24-03-2018 3:54 PM - edited 24-03-2018 3:55 PM
Good afternoon,
This morning our broadband connection has been dropping out and reconnecting and at slower than usual speeds, our connection may have become banded again.
We thought this issue was down to our very old thompson modem so we renewed our contract got a replacement router Plusnet 2704N Router - ADSL which was working perfectly all week and has been for at least the past three weeks, I have posted a screenshot of what we usually get below.
But now it keeps cutting out and the ping is slightly higher and the connection tends to drop out every hour or so it feels like a different connection, it shows a slower connection but more importantly it keep cutting out.
Can the connection be restored to how it was and the banding removed if it has reoccurred ?
Many thanks for your help.
Jrice
Fixed! Go to the fix.
Re: Broadband cutting out and slower speeds since this morning
25-03-2018 10:10 AM - edited 25-03-2018 10:12 AM
Yesterday was a pretty bad connection dropping a lot, today... Its slower but stable..
25-03-2018 11:24 AM - edited 25-03-2018 11:48 AM
I phoned Plusnet support who said my noise was too high on the modem and that I should try again in 4 hours when the signal to noise ratio should be lower. ?
I'm confused at why the modem has worked fine for three weeks always showing the fast 21mb connection but since saturday is being moved around via DLM like crazy dropping out each time.
Surely something has changed ?
We've been a plusnet customer for many years and only in the last 6-7 months have we had issues with DLM. We've bought a new modem in the hopes it will cure it, it did do for three weeks but now were back to unreliable.
Lots more drops outs this morning, will keep trying..
26-03-2018 11:51 AM
27-03-2018 5:09 PM - edited 27-03-2018 5:09 PM
Thanks Matthew,
It's stable now, but seems capped at 16mb via DLM. Last time it was rectified by resetting the profile or by doing the fix that HarryB performed. In the post below.
Could we get back to the speeds back to normal ?
Jrice
28-03-2018 11:41 AM
28-03-2018 6:41 PM
Thanks Adam will do.
29-03-2018 3:06 PM
Hi Guys,
Please update this if you manage to remove the current profile,
Jrice
30-03-2018 7:45 PM
Just a thought: Have you tried a Quiet Line Test? On a wired phone, dial 17070, select option 2 when prompted.
Do you hear any clicks, rattles, crackling, hissing, music, voices? If so, it's so much easier to raise a voice fault, which should resolve the underlying issue. Joints can go bad, trees can damage wires, etc.
Most phone lines were never designed to carry anything other than voice, so xDSL speed is on a "reasonable efforts" basis. But get the metallic path working right for voice and you'll generally get the best result for xDSL.
01-04-2018 4:15 PM
03-04-2018 4:58 PM - edited 03-04-2018 4:59 PM
Thanks Gandalf and Richi and Adam!
The line speed is now excellent again (for adsl), 8ms 21mb dl and 1.1 up
I hope it stays this good, thank you all for helping.
P.S I did try the line (recommended by Richie) test but the line always seems to check out when I do that test, this phone line has always sounded very clean to me.
Thanks everyone for their help with this.
I hope the lines current profile can be saved.
03-04-2018 5:14 PM
NP. Here's hoping DLM doesn't show its unwelcome face again. Try not to resync more than once a day!
04-04-2018 12:55 PM
