Broadband cuts of whilst on phone
mccoll2u
i have had to put up with broadband speeds going up and down since joining i have been putting up with it but now i have noticed if my girlfriend uses the homephone whilst i am on the net or xbox i loose broadband any idea whats up
Vip3r
Re: Broadband cuts of whilst on phone
Could be a faulty Microfilter (you have got a microfilter on each phone right?  Wink)
Home wiring, or a problem at the cabinet / exchange.
wacky17
Yup check your filters on the phone lines.
whelpton
Hi mccoll2u,
Do you hear any crackling or pops when using the phone or if you run a quiet line test by calling 17070 (option 2)?
mccoll2u
Hi changed the microfilters no success just dialed that number and yes there is a lot of noise on the line now
whelpton
What I would suggest would be to connect your phone to the test socket by itself and run the quiet line test once again. If there is still noise on the line then it would need to be reported to our support team as a home phone fault.
mccoll2u
yeah its still the same in the test socket in fact i was getting faint music it through it earlier so much so i could name the song so i guess that must be radio
whelpton
Certainly unusual behaviour. Either a crossed wire problem or possibly some em interferance somewhere on the line.
I would strongly reccomend giving our support team a call who could run a check on the line to see if anything pops up. I would do this myself but I am out of office until monday.
knowdice
Quote from: mccoll2u
Sounds like your master socket is incorrectly wired, could be that an extension is wired to the input side of the master rather than the isolated side.
Gel
Seasoned Pro
Fixes: 13
