Broadband connection
- Broadband connection
23-10-2015 4:02 PM
Hello,
My broadband is due to be activated on 27/10/15. My router is showing it is connected to the internet. However, it fails when I attempt to login using my username and password.
Is there any chance you can activate my broadband early as it appears to be connected.
Thanks,
Chris
Thanks,
Chris
Message 1 of 3
(739 Views)
2 REPLIES 2
Re: Broadband connection
23-10-2015 4:07 PM
Hi
I can see your connection is due to complete on Monday, this can be anytime hence our systems will send a message confirming you will be active the following day, at the moment not all work is complete however sometimes you can get a temporary connection whilst this is being done but generally this disconnects after a short while.
We cannot speed this up however everything is set to fully activate from Monday, everything is processing as expected.
Message 2 of 3
(271 Views)
24-10-2015 10:41 AM
I've activated your account on our systems, so you may be able to log in now. However we can't investigate a fault until the actual activation date.
Message 3 of 3
(271 Views)
