Broadband connection repeatedly disconnecting
- Broadband connection repeatedly disconnecting
13-07-2014 5:46 PM
Hi all,
over the last 2-3 weeks or so I've had repeated disconnections at various times during the day (twice in the last hour), sometimes at midnight. When this occurs I use my phone's mobile internet to check the service status of plusnet broadband and with the exception of the problems on the 10th of July (and the maintenance which occurred before the world cup from midnight to 6am), I've been having these disconnections when the service status has said that the problem should have been resolved.
Would it be possible to identify the cause of these intermittent disconnections? I should also point out that the router does not always think the internet connection has dropped (below you can see it says it has been up for 4 days).
Additional Information:
BT Wholesale tests: Download speedachieved during the test was - 10.42 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.86 Mbps
Upload speed achieved during the test was - 0.6Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
Information from router:
DSL Connection
Link Information
Uptime: 4 days, 17:09:36
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 828 / 12.315
Data Transferred (Sent/Received) [MB/GB]: 979,36 / 1,99
Output Power (Up/Down) [dBm]: 12,2 / 20,9
Line Attenuation (Up/Down) [dB]: 15,2 / 30,0
SN Margin (Up/Down) [dB]: 5,7 / 9,1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.569 / 0
FEC Errors (Up/Down): 140.830 / 14.012.644
CRC Errors (Up/Down): 245 / 37.797
HEC Errors (Up/Down): 192 / 379.800
Type: PPPoA
Uptime: 4 days, 17:11:25
IP Address: 87.115.151.149
Data Transferred (Sent/Received) [MB/GB]: 851,05 / 17,51
Regards,
Jon
DSL Connection
Link Information
Type: PPPoA
Regards,
Jon
Message 1 of 5
(950 Views)
4 REPLIES 4
Re: Broadband connection repeatedly disconnecting
13-07-2014 6:14 PM
as noted this would suggest you're not losing connection:
are you using wired or wireless connection when it seems to go awol?
Quote Type: PPPoA
Message 2 of 5
(552 Views)
13-07-2014 7:09 PM
wired
Message 3 of 5
(552 Views)
14-07-2014 11:00 AM
I can't see that your connection is dropping as shown here:
<img src="http://community.plus.net/visualradius/generated/image14053319692633.png"/>
I've checked on our suppliers systems and can't spot any drops in sync either. Can you check that your drivers are all up to date on your computer?
Message 4 of 5
(552 Views)
16-07-2014 1:21 AM
thanks for the fast reply chris, i think i was getting confused with how vpns work. internet seems to work fine, apologies for wasting your time.
Message 5 of 5
(552 Views)
