Broadband connection keeps dropping out
Hayley24
Hi all
Not sure if anyone can help but I've tried all the suggestions on the guides and am losing the will to live.
My connection keeps randomly dropping out (orange flashing light) and then 5 mins later comes back. Then it does it again. This is happening about 4 or 5 times an hour. 3 days in the last 2 weeks it's done this.
Any suggestions 🤷‍♀️
Hayley
4 REPLIES 4
Fixes: 334
Re: Broadband connection keeps dropping out
@Hayley24
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Hayley24
Hi John
Thanks for your message.
I do have a landline connection but don't have a phone 🤦‍♀️ Only ever use my mobile. Only had a phone line as one was needed for the broadband. So I can't actually check the line. I'll contact plusnet and go from there.
Thanks for your help
Hayley24
Well, I've reported the problem, they've run a test and apparently there is a fault and they need to send an engineer to sort it. Oh the joy 🤣
Thanks again for your help
Fixes: 235
A cheap handset can often save significant time in locating faults such as this.
