Broadband connection frequently dropping
- Re: Broadband connection frequently dropping
06-10-2022 9:31 AM
Over the last few months my broadband frequently drops with the router flashing amber, sometimes only briefly sometimes for over 10-15 minutes. I’ve tried moving the router and testing the connection straight to my laptop, didn’t seem to make a difference.
06-10-2022 9:44 AM
@Cat3 Welcome to the Community forum.
The first thing to do is report a fault, see. https://www.plus.net/help/report-a-problem/
06-10-2022 9:45 AM
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
09-10-2022 8:12 PM - edited 09-10-2022 8:13 PM
I'm really sorry to see your broadband's dropping frequently.
I've tested your line tonight and the tests are showing are showing what's known as a high resistance fault so we may have to arrange an engineer to investigate but I'd just like to check first that the problem's not caused by your router or wiring.
Are you using the router we've sent you a couple of years ago and is it plugged into the master telephone socket using just the cables we've sent also? It may also be worth plugging your router into what's known as the test socket explained Here as this will rule out an issue with internal wiring which could be affecting your connection.
10-10-2022 4:20 PM
The router is plugged in with only the cables supplied and there is only one phone socket in the flat.
10-10-2022 4:24 PM - edited 10-10-2022 4:24 PM
Thanks for getting back to me Cat.
Ah okay no problem, in that case I think it'd be best to arrange an engineer visit to take a closer look.
What days could you be available? The engineers work 8am to 1pm or 1pm to 6pm.
10-10-2022 5:12 PM
11-10-2022 9:05 AM - edited 11-10-2022 9:08 AM
I've reported a fault with our suppliers and they're carrying out some diagnostic first before arranging an engineer.
In the meantime, did you know that fibre is available in your area? You can either get regular fibre of speeds up to 76mbps, or "full fibre" of speeds anywhere up to 900mbps. If you'd like to upgrade, there'd be some offers in your account Here, alternatively I'll be happy to ask one of my colleagues in our Customer Options Team to call you back.
[edit]
Well those diagnostics didn't take long. We've been given the option to call out engineer so I've arranged this for tomorrow.
