Broadband connection dropping out repeatedly (Plusnet Hub2 router)
sallonoroff
After a couple of years of a fairly solid connectivity, we've had a flakey connection for the last couple of weeks. The line appears to disconnect randomly, just for a few seconds at a time. I think it was worst on Monday this week when it dropped about 7 or 8 times during the day (that i noticed). I restarted the router and that appeared to help as it only dropped out once yesterday, but maybe that was coincidence/good fortune as it has started dropping out again today.
Is someone at Plusnet able to check logs for my connection and see where the problem may lie please?
Thanks.
24 REPLIES 24
Legend
Fixes: 290
Re: Broadband connection dropping out repeatedly (Plusnet Hub2 router)
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
sallonoroff
Thanks for the quick reply John.
I'd not thought of that as I don't think we've plugged a phone in since we moved here a few years ago!
I'll have to go and hunt the old phone out. Some kind soul at PN may have reviewed the logs before i achieve that. 😄
Legend
Fixes: 290
I doubt you will get that speedy a response on here, TBH, staff monitoring is sparse, which is why some of the Community members try and help.
sallonoroff
Oh, that's a shame. It used to be quicker to get a response from someone who knew what they were doing here than by trying to navigate the call centre. One of the reasons I've stayed with PN for 15 years or more, in fact, despite the price only ever increasing. If this one nicety is gone, then i might as well look at getting Full Fibre (with a new customer discount) elsewhere when my current contract is up.
Legend
Fixes: 290
That is an option, but you will usually get fast responses from Community members which can avoid the need for the call centre.
sallonoroff
Just a quick update to say that i finally found an old landline phone and tried 17070 option 2. I couldn't hear any sort of noise on this Quiet Line test, so i'll report a broadband problem.
I had a quick look in the router's logs to see if anything jumped out at me (not knowing what i'm really looking for). At the time of each cut-off it just says "DSL Line Down", and nothing immediately beforehand, which suggests it's nothing to do with the Hub2 itself?
Don't know if relevant/helpful, but i've also copied the current line stats while i was in there:
Data rate: 10 Mbps / 39.999 Mbps
Maximum data rate: 22.643 Mbps / 72.708 Mbps
Noise margin: 15.1 / 11.7
Line attenuation: 12.1 / 19.1
Signal attenuation: 12.0 / 21.8
Cheers.
Legend
Fixes: 290
@sallonoroff Looking at those stats, you certainly have a problem. You have got a capped upload/download, and SNR fifgures, and from what you have said, are suffering constant xDSL drops as the DLM attempts to  stabilise your connection.
Let us know what the results of your report are.
sallonoroff
Thanks John.
If you're referring to it being 40/10, that's because that's all i pay for. I originally had the higher rate package but was only getting about 40mbps downloads anyway, so dropped down to the cheaper option.
I tried to log the fault last night but the bot just kept saying i needed to speak to an advisor (which wasn't possible because of the time of day).
Legend
Fixes: 290
@sallonoroff Just for my interest, can you post a screenshot of your Hubs information page, where you got those figures in post #7 from - obscure personal details?
Report it today.
sallonoroff
I've reported it now. OpenReach are coming tomorrow. 👍
The figures came from the "Advanced Settings" > "Technical Log" > "Information" page of the router.
Legend
Fixes: 290
Thanks - the only reason I asked for that screenshot was to check your line/signal attenuation, which confirmed my suspicion that you were a distance from the cab, thus making your copper connection a bit long.
sallonoroff
I've also realised I can export the log and have done that to search for all instances of "DSL Link Down".
It dropped in June 2022, and a few times in March 2023, and then started dropping lots on the 14th November.
10 times on Monday!
09:42:04 06/12/2023 DSL Link Down: duration was 109206 seconds
03:21:28 05/12/2023 DSL Link Down: duration was 43669 seconds
15:13:09 04/12/2023 DSL Link Down: duration was 22 seconds
15:12:16 04/12/2023 DSL Link Down: duration was 369 seconds
15:04:38 04/12/2023 DSL Link Down: duration was 26 seconds
15:03:42 04/12/2023 DSL Link Down: duration was 79 seconds
15:01:53 04/12/2023 DSL Link Down: duration was 33 seconds
15:00:50 04/12/2023 DSL Link Down: duration was 13307 seconds
11:18:33 04/12/2023 DSL Link Down: duration was 26522 seconds
03:56:01 04/12/2023 DSL Link Down: duration was 2382 seconds
03:15:49 04/12/2023 DSL Link Down: duration was 923 seconds
02:54:05 04/12/2023 DSL Link Down: duration was 434206 seconds
02:16:49 29/11/2023 DSL Link Down: duration was 25 seconds
02:15:54 29/11/2023 DSL Link Down: duration was 48 seconds
02:14:36 29/11/2023 DSL Link Down: duration was 963 seconds
01:58:03 29/11/2023 DSL Link Down: duration was 30 seconds
01:57:03 29/11/2023 DSL Link Down: duration was 2404 seconds
01:16:29 29/11/2023 DSL Link Down: duration was 1501 seconds
00:50:58 29/11/2023 DSL Link Down: duration was 24929 seconds
17:54:59 28/11/2023 DSL Link Down: duration was 8994 seconds
15:24:35 28/11/2023 DSL Link Down: duration was 229 seconds
15:20:16 28/11/2023 DSL Link Down: duration was 33316 seconds
06:04:30 28/11/2023 DSL Link Down: duration was 96 seconds
06:02:24 28/11/2023 DSL Link Down: duration was 876 seconds
05:47:18 28/11/2023 DSL Link Down: duration was 9240 seconds
03:12:48 28/11/2023 DSL Link Down: duration was 406 seconds
03:05:32 28/11/2023 DSL Link Down: duration was 33 seconds
03:04:29 28/11/2023 DSL Link Down: duration was 96715 seconds
00:11:59 27/11/2023 DSL Link Down: duration was 2049 seconds
23:37:21 26/11/2023 DSL Link Down: duration was 43036 seconds
11:39:35 26/11/2023 DSL Link Down: duration was 21 seconds
11:38:44 26/11/2023 DSL Link Down: duration was 105227 seconds
06:24:27 25/11/2023 DSL Link Down: duration was 58574 seconds
14:07:07 24/11/2023 DSL Link Down: duration was 73 seconds
14:05:25 24/11/2023 DSL Link Down: duration was 59227 seconds
21:37:48 23/11/2023 DSL Link Down: duration was 59353 seconds
05:08:05 23/11/2023 DSL Link Down: duration was 26 seconds
05:07:09 23/11/2023 DSL Link Down: duration was 100076 seconds
01:18:43 22/11/2023 DSL Link Down: duration was 2051 seconds
00:44:02 22/11/2023 DSL Link Down: duration was 35 seconds
00:36:58 22/11/2023 DSL Link Down: duration was 16788 seconds
19:56:03 21/11/2023 DSL Link Down: duration was 7087 seconds
17:57:26 21/11/2023 DSL Link Down: duration was 107987 seconds
11:57:09 20/11/2023 DSL Link Down: duration was 204036 seconds
03:16:03 18/11/2023 DSL Link Down: duration was 4562 seconds
01:59:31 18/11/2023 DSL Link Down: duration was 31 seconds
01:58:30 18/11/2023 DSL Link Down: duration was 4049 seconds
00:50:31 18/11/2023 DSL Link Down: duration was 347 seconds
00:44:14 18/11/2023 DSL Link Down: duration was 17871 seconds
19:45:52 17/11/2023 DSL Link Down: duration was 32865 seconds
10:37:37 17/11/2023 DSL Link Down: duration was 10599 seconds
07:40:28 17/11/2023 DSL Link Down: duration was 10017 seconds
04:52:25 17/11/2023 DSL Link Down: duration was 50 seconds
04:51:00 17/11/2023 DSL Link Down: duration was 31 seconds
04:49:59 17/11/2023 DSL Link Down: duration was 55692 seconds
13:21:17 16/11/2023 DSL Link Down: duration was 23 seconds
13:20:24 16/11/2023 DSL Link Down: duration was 27 seconds
13:19:27 16/11/2023 DSL Link Down: duration was 32681 seconds
04:14:16 16/11/2023 DSL Link Down: duration was 5448 seconds
02:42:22 16/11/2023 DSL Link Down: duration was 4640 seconds
01:24:33 16/11/2023 DSL Link Down: duration was 57126 seconds
09:31:56 15/11/2023 DSL Link Down: duration was 7986 seconds
07:18:20 15/11/2023 DSL Link Down: duration was 38104 seconds
20:42:46 14/11/2023 DSL Link Down: duration was 53 seconds
20:40:47 14/11/2023 DSL Link Down: duration was 21 seconds
20:39:56 14/11/2023 DSL Link Down: duration was 7634 seconds
18:32:12 14/11/2023 DSL Link Down: duration was 21 seconds
18:31:21 14/11/2023 DSL Link Down: duration was 607 seconds
18:20:44 14/11/2023 DSL Link Down: duration was 2264350 seconds
09:45:34 30/03/2023 DSL Link Down: duration was 838240 seconds
15:54:24 20/03/2023 DSL Link Down: duration was 21 seconds
15:53:32 20/03/2023 DSL Link Down: duration was 916409 seconds
03:39:57 04/06/2022 DSL Link Down: duration was 260433 seconds
sallonoroff
I don't know where the nearest big green cabinet is, but there's a smaller grey one less than 25 metres away. We're on an estate where the lines are in ducts, not on telegraph poles.
Legend
Fixes: 290
They grey one isn't an Openreach one -maybe Virgin, or for some other utility.
