Broadband connection dropping out frequently
Barry3
My broadband connection has been dropping out frequently over the last 10 days. In fact its got so bad that I'm having to use a wifi hot spot on a mobile phone just to post this message and go through the broadband trouble shooter. I'm waiting to get a new microfilter so i can test that before logging the fault, but is there anything else that I can do to sort this out?
ta
Barry
Fixes: 166
Re: Broadband connection dropping out frequently
Happy to have a look and see if I can spot anything from a line test if you PM me your username.
Please send me a private message
 Chris Parr
 Plusnet Staff
Fixes: 166
Thanks for the PM.
Our tests are showing the line quality isn't look great:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 15.1 31.0
SNR Margin: 30.0 11.8
Errored Seconds: 0 3
HEC Errors: 0
Cell Count: 2745877 3917495
Speed: 444 11284
Maximum Stable Rate (KBPS): 6816 Fault Threshold Rate (KBPS): 5452
Mean Time Between Retrains (Seconds): 2654 Mean Time Between Errors Upstream (Seconds): 13935
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 105
We can see a lot of disconnections:
Is the phone line clear? No noise when you pick up a handset and dial 17070 running the quiet line test?
 Chris Parr
 Plusnet Staff
Barry3
Hi
No, the line seems fine and I cant hear anything on the quiet line test.
Fixes: 198
I'd recommend raising a fault at http://faults.plus.net
Let us know once you've completed this.
 Harry Beesley
Barry3
Will do. Thanks very much for your help, one last quick question. I've gone through everything on the broadband problems page but ts asking me to text my connection with a different router. Do i need to do this, or is it definitely a problem with the line?
Ta
Barry
